D600 will not connect to wireless antenna is off
investtoenrich
Hello,
i have a d600 and it is not connecting to internet. How do i turn on the antenna on this laptop. the wireless in house is working other computers are connected. ?
Ted
visa
140
You can try pressing the function key (Fn) and F2 at the same time to toggle the wireless on and off.
If that doesn't work, you may want to check device manager to ensure that the wireless card is installed and working properly.
