Archived from groups: alt.sys.pc-clone.dell (
More info?)
I meant exactly what I wrote.
Dell has a DKB article that's kept tightly under wraps that lists DELL OEM
COAs for certain applications.
Or -- at least -- they did. It takes a sharp tech to find it.
"Christopher Muto" <muto@worldnet.att.net> wrote in message
news:VmY4d.11$va.7@trndny03...
> did you mean 'cd' instead of 'coa'? i have not heard of dell ever giving
> a
> replacement coa. getting a replacement cd outside of the total
> satisfaction
> return period has never been successful for me, though others have
> suggested
> here that is possible (if you get a cooperative tech that is willing to do
> the paperwork and if they have the cd available). also, the boot floppies
> work the same as the cd (locked to dell bios) unless you replace the
> aforementioned file...
> "Dick Silk" <dick_silk@anti-spam.net> wrote in message
> news:4153758c$2_3@newspeer2.tds.net...
>> I am aware that Dell restore CDs only work on Dell BIOS'd motherboards.
>> So if he wants a Dell restore cd, then chances are he has a Dell
>> motherboard.
>> Now, I'm just guessing at that part, but that's logical.
>> If he's lost his COA to his Dell PC, he can call <gasp!> tech support,
>> and
>> they can give him a Dell OEM COA.
>> In fact, if he finds my true e-mail address from my website and e-mails
> me,
>> I'll send him the Dell OEM COA.
>> You're right, by the way, about the boot floppy issue. When Dell
>> distributed W2K to the techs to take home and test, they had to generate
> the
>> 4 floppies because most of the techs didn't have Dells at home! The
> floppy
>> method you described was their "workaround" solution.
>> news:BmK4d.18214$%42.15957@trndny08...
>> >i suppose the op's motivation for wanting a dell cd is two fold... one,
>> >the
>> > serial number the op has is the dell oem one and oem serial number only
>> > work
>> > with the oem packaged version of the os (not the retail version), and
> two,
>> > most oem win2k cds are tied to the system bios... but the work around
>> > would
>> > be this... get any oem win2k cd, then using the makeboot utility found
> on
>> > the cd create a set of boot floppies, and the replace the setupldr.bin
>> > file
>> > found on the first floppy with the one found on a dell oem win2k cd
>> > (easily
>> > sent via email). boot with the new and modified floppies and the other
>> > vendors cd will work and the serial number will work too.
>> > news:41536730$1_2@newspeer2.tds.net...
>> >> this may seem like a stupid question, but it isn't:
>> >> WHY do you need a dell / W2K recovery cd?
>> >> If you have one that doesn't *seem* to work, try this: run the
>> >> install
>> >> using ALL defaults. Don't change a THING unless you absolutely MUST,
> and
>> >> even then, think TWICE: can you install it as default and change it
>> > later?
>> >> Doing this will make a Dell W2K restore cd that doesn't SEEM to work,
>> >> actually work.
>> >> R.C. Silk -- The Computer Tutor
>> >> *Help for Humans in Need*
>> >> http://personalpages.tds.net/~rcsilk/
>> >> http://dicksilk.chatango.com/ (for live chat)
>> >> --Am I a tagline?? I don't remember........
