Archived from groups: alt.sys.pc-clone.dell (More info?)
My Dell 4300 comes with a SoundBlaster Live/Value sound card. I am
trying to route the audio to my TV, then I can play recorded TV shows
(in MPEG) in the TV. But I don't seem to find a way to connect the
audio output to the TV. Please help.
The sound card comes with various ports at the back, and it also has a
head phone jack to the front of the computer case. The ports at the
back are:
- 2 for speakers
- 1 for microphone that is not being used
- 1 is an Line-In that I connect the audio cable from my DirecTV
decoder box
- 1 is called Digital Audio that is not being used (I have no idea
what it is)
I have tried to connect my TV to the Digital Audio port. But it
doesn't work (obviously because the TV is expecting analog audio).
I don't bother to try the microphone port because that is for voice
input, not output.
Is connecting to the headphone jack the only one out? If this is the
case, I may as well forget about this and listen to the audio from the
PC speaker directly (I don't want to see a cable constantly being
plugged into the front of the PC).
Connect it to the green speaker out connector. Works fine to a TV or
amplifier.
Tom
"Jay Chan" <jaykchan@hotmail.com> wrote in message
news:c7e5acb2.0405171227.3478e966@posting.google.com...
> back are:
> - 2 for speakers
> decoder box
> what it is)
> input, not output.
> Thanks in advance for any help.
> Jay Chan
> amplifier.
I am wondering what I should do with the PC speakers then. If I use
the speaker out port to connect to TV, the PC speakers will not be
connecting to anything, right? Am I missing something?
news:c7e5acb2.0405180407.3824c06f@posting.google.com...
>> amplifier.
> Jay Chan
Go to Radio Shack (etc.) and find a splitter/adapter.
speakers in TV *OR* PC speakers, pick one!
> > amplifier.
> Jay Chan
> > amplifier.
THIS WILL SOLVE YOUR PROBLEM:
The green port is for the speakers for a normal PC setup (and also for the
front speakers of a 4-point or faux "surround" setup).. The black port is
for the rear speakers in a surround setup. You should be able to connect the
PC speakers to the green port and your TV to the black port and be just
fine. (The same audio is sent to both ports by default or when in
"non-surround" mode). This functions just like the splitter (Or Y-cord)
another poster recommended. Except it's much more efficient and sounds
better.
You will need a special cord to hook up the Soundblaster to the TV (I'm
assuming your TV uses RCA jacks). You need at 1/8"-stereo-to-dual-RCA chord
like this:
http://www.radioshack.com/product. [...] 42%2D2483. (Be sure to get one long enough for your needs). The single pointed
connecter goes into the SBLive's black port and the two RCA connectors on
the other end go to the TV (Red for right channel, White for left channel).
If you're into electronics you may have enough components around the house
to make one of these up with a few adapters.
> better.
Good to hear that there is a solution to my problem. I will try to
experiment with this and see what happens.
If somehow this doesn't work, I will try the splitter that another
newsgroup member has suggested.
> like this:
news:c7e5acb2.0405190836.26f88c0e@posting.google.com...
the
is
the
> > better.
If it doesn't work before you go out and buy a splitter be sure to look in
the Creative Surround Mixer app (in their Start Menu). You may have to
fiddle with a few things there to turn the sound on (but I think it's on by
default).
> default).
Thanks for the tip. I will try this in this evening or tomorrow
evening.
I didn't your last tip last night because I was struggling to get the
S-video thing to work -- and the S-video thing still doesn't work. But
that is a different story.
I decided to get a splitter and used it to connect to the green
speaker port in my PC. It works.
I didn't try your tip of "not-using-the-splitter but
use-black-port-for-TV and green-port-for-PC-speaker" because I still
don't understand why that tip could work considering the fact that
both the green port and the black port in my PC have already been used
and are not free. I hope you don't feel offended.
news:c7e5acb2.0405240622.12154a84@posting.google.com...
> Jay Chan
Whatever works. This has been a helpful thread on an issue that doesn't come
up a lot.
