G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
I probably over my head on this repair job anyway..... I wanted to ask
a few questions to help me come to a decision on what I ought to do.
I picked up a project Pin-Bot that was DOA. I rebuilt the high voltage
board and replaced all the chips. The game now powers up with the
exception of rows 1 through 4. Those switches seem to be locked on.
When the game is turned on the two coils for the eyes (sw 25 and 26)
will alternate firing. When is switch edge test, engaging any switch in
the first 4 rows it will activate several switches.
While doing my reading, trouble shooting system 9 machines, it mentions
that if all rows 1 through 4 are locked on you could have a problem
with U51 or U52. It mentions that a short could happen between Flipper
EOS switch touching the lane change switch. When looking over the game
I noticed that someone recently replaced the EOS switch recently on the
right flipper and the soldering was done poorly. There are a few
strands of wires hanging freely. Dumb question but, am I right to
assume that the Lane change switch is the second set of switches
attached to the EOS switch?
My soldering skills are not first-rate. Replacing chip U51 or U52 needs
to be done by a professional. Any ideas on what else I might want to
check before I have to send the board off to get repaired?
Thanks,
Jeff
Thanks,
Jeff
