G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
I've still been working on this Black hole. Here are my current
problems:
With everything connected: GI lights in the head are all that work,
except for ONE light on the playfield (shoot again when lit)
With the CPU, Driver, and sound board out, I get all of the current
voltages at the PS board. With them CPU in, I get only 4.3 on the CPU
ROM. With CPU and Driver, I get only 4.1 at the driver. Obviously the
PS board is dropping way to much with the load...why? Also, this is a
new PS board from Rottendog Amusements.
Other strange occurences (maybe 5v related?):
With only the CPU-Driver connector undone(everything else in place), I
get GI lights in Head and PLayfield and I get score displays, but not
the attract-mode lights. It will accept credits and if I hit start it
subtracts a credit and says ball in play. No drivers work.
With only A1-J6 disconnected, it goes through the attract light
sequence, accept credits, and appears as thought it will work. The
captive hole on the lower playfield remains energized though. When I
hit start, it very weakly pushes the balls in the trough. No points
register.
I've done all the mandatory mods, including connectors. Everything in
the cab is testing OK as far as fuses, transistors, resistors and
everything on the playfield. The CPU (with different ROM in it) and
Driver were tested in a different System 80 machine (Time Line?) and
did fine, but that machine doesn't use all of the same drivers and
obviously this doesn't test my ROM, but otherwise they worked 100%.
That's it for now.
Any ideas? What should I do next?
problems:
register.
That's it for now.
