Acer e machine 525 battery regarding
Hello,
i own an acer e 525 . when i turn on after 10 mins the system goes standby (when running on batteries). and after i hit the enter button the batteries show 0% but it will run for 30-35 mins.pls help me
1 answer Last reply
More about acer machine battery regarding
  1. To deal with the stand by issue, go to the power properties and adjust the setting where it goes into standby. If that doesn't do the trick and combined with the other issues, try running it without the the battery (just AC power) and see if it does the same thing. If it doesn't, I suspect then that it is probably a battery that is on it's way out- even though it is still holding a charge.
Battery Acer eMachines Laptops
