Archived from groups: microsoft.public.windowsxp.general,microsoft.public.windowsxp.hardware (More info?)
I have taken out a subscription to Bulldog broadband (part of C&W in the UK) which claims to supply [upto] 8 MB per second download. Is there anyway this can be checked?
This company is the only one offering such a high speed while its rivals are offering only 2 mb per second for the same price. Surely there must be a catch somewhere and if so how can this be checked?
Thanks.
> Thanks.
dslreports.com - Speed test
http://www.dslreports.com/stest?loc=2
Bruce Chambers
Help us help you:
http://dts-l.org/goodpost.htm
http://www.catb.org/~esr/faqs/smart-questions.html
You can have peace. Or you can have freedom. Don't ever count on having
both at once. - RAH
"Mahesh Patel" <anon@global.com> wrote in message
news:74019022.926B1993@newsgroups.com...
> Thanks.
Hi
Speeds of 8mb can only be achieved by cable
A max of 2mb From landine
Go here for a test
http://www.adslguide.org.uk/tools/speedtest.asp
Chas
You can also run NetStatLive from www.analogx.com
| Thanks.
"Chas" <charles@prattindustriestheobvious.wanadoo.co.uk> wrote in message
news
Xf8IKZsFHA.1028@TK2MSFTNGP12.phx.gbl...
>> Thanks.
> Hi
> Go here for a test
> Chas
Funny; I have 5MBps DSl (landline). Didn't know I was getting something
that does not exist.
FWIW, a broadband Cable provider can "claim" whatever they want. What they
actually deliver is quite different. Be aware that you are sharing the
"*MBps" with everyone on your "node", so in the evening you speeds will be
reduced due to the large number of users sharing "the pipe". This does not
occur with DSL.
DSL is quite capable of greater speeds than cable, provided you FIOS to the
home. Cable has a theoretical 8MBps, but due to broadcat overhead and
multiplexing, real world limit is just under 6MBps with cable.
In my case I have fibre to the curb, thus the 5MBps limitation. It costs
less than cable, and I get the bandwidth I am paying for all the time,
unlike cable.
YMMV.
Bobby
http://www.bandwidthplace.com/speedtest/
regards,
ssg MS-MVP
> Thanks.
Archived from groups: microsoft.public.windowsxp.general (More info?)
On Sun, 4 Sep 2005 14:59:03 -1000, "NoNoBadDog!"
>occur with DSL.
This is just another of those myths of broadband that DSL providers
use to try to convince cable internet users that the DSL service is
better.
This alleged "slow down" has never occurred on my cable internet
hookup no matter what time of day I am using it.
In article <vcmoh1562e35l6kqgs12410n60o6pjo26a@4ax.com>, Rctfreek
says...
> >occur with DSL.
> better.
Yea, DSL is shared to - at the network back end, so, like with many DSL
providers, they over-sell and you don't get the performance the
"suggest" that you might get.
spam999free@rrohio.com
remove 999 in order to email me
At least with DSL, ADSL or Cable, one doesn't have to jump through the WPA
and WGA hoops.
Alias
In article <uMLY7xisFHA.3080@TK2MSFTNGP15.phx.gbl>, aka@[notme]
maskedandanonymous.org says...
> and WGA hoops.
Wrong, you have a WGA/WPA type situation with SBC DSL - you have to
Install their software in order to validate before they will let you
have open internet access with their services. We just did 11 different
SBC DSL connections, each one required that their Software be installed
in order to Authenticate with SBC and enable the modem to be used for
out of SBC access.
I've also seen this happen in another ISP that provides Cable service
(can't remember the ISP name, but I could get it if you need the
reference).
What about all the Hotels that require you to get a Key before they will
let you use their Hot-Spot access - seems like, under your ideas, that
they are assuming customers are thieves too.
"Leythos" <void@nowhere.lan> wrote in message
news:MPG.1d862fa08c636d7e989ebd@news-server.columbus.rr.com...
>> WPA
>> and WGA hoops.
> out of SBC access.
I have cable and installed no software to get it going other than XP. I have
friends with ADSL and same story.
> reference).
Perhaps it's a JesusLand trip, assuming everyone is a thief.
I would suspect they are trying to prevent non registered hotel patrons from
accessing their WiFi. That's called security, not activation.
Alias
In article <enzScCjsFHA.2064@TK2MSFTNGP09.phx.gbl>, aka@[notme]
> >> WPA
> >> and WGA hoops.
> > out of SBC access.
I didn't say it impacted every one - just the last 6 months of SBC DSL
we've installed and one Broad-Band provider.
> > reference).
I don't see how that's different that trying to prevent unauthorized
people from running/using Windows software? In either case the provider
assumes that I'm not suppose to use their service by default.
news:MPG.1d8632c42f1ba78f989ec2@news-server.columbus.rr.com...
>> >> > DSL
>> >> WPA
>> >> and WGA hoops.
>> > out of SBC access.
>> have
I should have rephrased that. In Spain, no Internet provider requires
activation. Tell the idiots at SBC that they can turn it over at their
central office and authentication isn't necessary.
>> > reference).
Hello?
>> > will
>> from
I never claimed you were capable of thinking logically.
Alias
In article <eMbHtIjsFHA.2880@TK2MSFTNGP12.phx.gbl>, aka@[notme]
I would agree, many of the DSL providers only require a user/password
and everything works out of the box. I don't know why SBC started doing
this, but it's a pain.
news:MPG.1d863ed92cfc84bf989ec9@news-server.columbus.rr.com...
So that their name appears on OE and IE?
Alias
In article <er6Eu0jsFHA.3216@TK2MSFTNGP12.phx.gbl>, aka@[notme]
No, you only need the software to "activate" the DSL modem so that it
will provide proper outbound access. Until you activate it, you can only
reach their service via their software.
Once you set it up, unless you know enough to ask for it to be
configured for BRIDGE MODE you get a hacked private IP with a funky DNS
setting. It is like having a NAT with all ports forwarded inbound, but
it won't always do DNS properly if you install a router.....
Once it's done, you can do anything, but it's getting it setup that is
the PITA.
news:MPG.1d8648333f00253f989ece@news-server.columbus.rr.com...
> the PITA.
You're giving me a headache just thinking about it.
Alias
In article <OyYcPQksFHA.3452@TK2MSFTNGP14.phx.gbl>, aka@[notme]
> > the PITA.
Yea, it was a real pain when they started that. I won't use SBC if we
get a chance. There are many simple DSL ISP's that just require a
user/password and the connection work - public IP, no port blocking,
etc... Makes setting up a inbound network easy and painless. SBC just
makes it hard for some unknown reason.
In news:vcmoh1562e35l6kqgs12410n60o6pjo26a@4ax.com,
Rctfreek <Rctfreek> typed:
>> speeds
>> will be reduced due to the large number of users sharing "the
>> pipe".
>> This does not occur with DSL.
> providers
> service is
> better.
> internet
If that's your experience, I'm glad to hear it, but you're
apparently more fortunate than most. I know many cable
subscribers who have experienced it. I'm a DSL user myself and
can't personally attest to it, but it clearly occurs, at least in
some locations and at some times.
Ken Blake - Microsoft MVP Windows: Shell/User
Please reply to the newsgroup
There are 1111 identified and unidentified users. To see the list of identified users, Click here.
