Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > xp won,t load can anyone help
Archived from groups: microsoft.public.windowsxp.general (More info?)
i did a system restore on my husbands pc now i am getting the message:
Explorer.Exe - Unable To Locate Component
This application has failed to start because BROWSEREUI.dll was not found.
Re-installing the application may fix this problem
Thanking You in anticipation
Sponsored Links
Hi,
I think you meant browseui.dll, and if this is the case you can expand a new
one from the I386 folder. Start/run msconfig, click on "expand file"
(general tab)
File to expand: browseui.dll
To: C:\Windows\system32
This assumes a default installation to C:\Windows. If your installation is
in a different folder, such as C:\Winnt, change the "To" path accordingly.
Reboot when finished.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Associate Expert - WindowsXP Expert Zone
www.microsoft.com/windowsxp/expertzone
Windows help - www.rickrogers.org
"Jacs" <Jacs@discussions.microsoft.com> wrote in message
news:E95200B5-DC47-46DD-8AB3-7451B4CF652D@microsoft.com...
Reply to Anonymous
There are 477 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
