Archived from groups: microsoft.public.windowsxp.general (More info?)
I have a persistent problem with the screen freezing necessitating a reboot.
It can happen randomly when I'm doing anything, but most obvious when I try
and start games/ applications. These just hang. I have run out of ideas what
it could be. I have reformatted hard drive 3 times to try and fix this, but
problem occurs with only OS, motherboard Nvidia nforce 4 drivers and graphics
drivers installed. I've updated all drivers, graphics, motherboard as well
as Bios. I've replaced the power supply and hard drive is also new. CPU is
not overheating. Could it be a flacky electical connection in the case, or
faulty optical mouse?
Does anyone have any ideas/ suggestions to help? This is driving me crazy!
AMD 64 3200 Venice
K8N Neo4 F MoBo
Gecube ATi X800XL 256 video
2 X Corsair 512 RAM
450 watt power supply
Win XP SP2
Last time it happened event viewer showed:
Event Type: Error
Event Source: Service Control Manager
Event Category: None
Event ID: 7026
Date: 5/09/2005
Time: 9:44:06 PM
User: N/A
Computer: MSI
Description:
The following boot-start or system-start driver(s) failed to load:
atitray
It doesn't always give same message though. Doesn anyone know what this
means and how can I fix it?
> reboot.
> I try and start games/ applications. These just hang. I have run out
> of ideas what it could be. I have reformatted hard drive 3 times to
> try and fix this, but problem occurs with only OS, motherboard Nvidia
> well as Bios. I've replaced the power supply and hard drive is also
> new. CPU is not overheating. Could it be a flacky electical connection
> in the case, or faulty optical mouse?
> crazy!
> AMD 64 3200 Venice
> K8N Neo4 F MoBo
> 2 X Corsair 512 RAM
> Win XP SP2
> Event Type: Error
> Event ID: 7026
> Date: 5/09/2005
> Time: 9:44:06 PM
> User: N/A
> Computer: MSI
> Description:
> atitray
> this means and how can I fix it?
Strip the machine down to the motherboard, video card, and one stick of
RAM. Run RAM tests - I like Memtest86+ from www.memtest.org. If the RAM
fails, replace it. Run some burn-in software (non-Windows). If the
machine stays up with no errors, start adding in pci components,
drives, etc. one item at a time, testing after each change. You can
also swap out the video card for a cheapo one to test.
Doing hardware testing requires having components on hand and a lot of
patience. If you don't, then take the machine to a professional
computer repair shop (not your local equivalent of BigStoreUSA). There
is no shame in doing this. Hardware faults can be really hard to track
down.
Thank you for the advice. What do you mean by burn- in software? I've done a
mem test as is and no problems detected. You think I should test one stick at
a time? Could faulty case wiring do this?
"Malke" wrote:
> > reboot.
> > crazy!
> > AMD 64 3200 Venice
> > K8N Neo4 F MoBo
> > 2 X Corsair 512 RAM
> > Win XP SP2
> > Event Type: Error
> > Event ID: 7026
> > Date: 5/09/2005
> > Time: 9:44:06 PM
> > User: N/A
> > Computer: MSI
> > Description:
> > atitray
> down.
> Malke
> Elephant Boy Computers
> www.elephantboycomputers.com > "Don't Panic!"
> MS-MVP Windows - Shell/User
> done a mem test as is and no problems detected. You think I should
> test one stick at a time? Could faulty case wiring do this?
If Memtest didn't show any problems, then you don't need to test the
sticks individually. I have some system testing software I use. Google
for "Hiren's Bootdisk". Sometimes m/b testing software is useful,
sometimes not. Basically, you've got to swap out components
methodically to find out where the problem lies. Sure, faulty case
wiring could do it, or even an optical drive that is shorting out the
psu. Or you could have a bad video card. Or a bad AGP slot. Or... you
get the picture.
Burn in software could include something like SiSoft Sandra.
Another thing to try is to remove the board from the case. attached what you
need to it and run it from out side of a case. If you consult the
motherboard manual you will see which pins to short out to power up or just
touch the two pins that the case power switch connects to with a screw
driver to short the pins and start up. If it runs fine outside of the box
then it is possible that the board is shorting against the case.
"thepcdoctor" <thepcdoctor@discussions.microsoft.com> wrote in message
news:EA85A6EF-CC8C-4777-AF40-7A81F4A5D811@microsoft.com...
> a
> at
> "Malke" wrote:
>> > reboot.
>> > crazy!
>> > AMD 64 3200 Venice
>> > K8N Neo4 F MoBo
>> > 2 X Corsair 512 RAM
>> > Win XP SP2
>> > Event Type: Error
>> > Event ID: 7026
>> > Date: 5/09/2005
>> > Time: 9:44:06 PM
>> > User: N/A
>> > Computer: MSI
>> > Description:
>> > atitray
>> down.
>> Malke
>> www.elephantboycomputers.com >> "Don't Panic!"
