Tom's Hardware > Forum > Systems > Dell > Sources For Dimension 8100 Power Supply
Forum Systems : Dell - Sources For Dimension 8100 Power Supply
Archived from groups: alt.sys.pc-clone.dell (More info?)
Can anyone point me to sources for a Dimension 8100 power supply? My
system's supply burned out and I can see that it's not a standard ATX
unit. >:-( http://www.pcpowercooling.com has a compatible unit, but
it's $100, which is a lot to spend fixing a 3.5 year old system,
especially for just a PS replacement.
Alternatively, has anyone sucessfully rewired an ATX PS to work with a
D8100? I managed to do this with an ATX for an old Motorola Mac
clone, but it was quite a pain. This job looks like it might be even
worse.
Thanks, any input appreciated.
Sponsored Links
You are in Luck. I repair all types of PC Power Supplies. I have an online
form you can fill out to get Started.
http://www.technotronic-dimensions.com/submit.htm
I just Fixed a Customers Dimension 8200 for a different problem which
probably has a Similar unit. From what I can tell, the MOBO Connector is Std
ATX on this one. You can also post a Picture to my Support Message Board of
the Old Supply just to be sure.
http://www.technotronic-dimensions.com/supportbbs
Sounds like I could keep the costs down to about half of the cost of the New
one.
"NMR Guy" <nmr_guy@hotmail.com> wrote in message
news:532a7ef6.0405221531.273b684a@posting.google.com...
| worse.
Reply to Anonymous
8200 yes
8100 no
The 8100 was a proprietary power supply.
Tom
"techforce" <toomuchspam@messedup.com> wrote in message
news:PeudnfbvxpfsZzLdRVn-sw@adelphia.com...
Std
of
New
> one.
> | worse.
Reply to Anonymous
> worse.
Just out of curiosity, what is it about the D8100 that makes it incompatible
with a standard ATX power supply?
Reply to Anonymous
There are 1303 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
