Solved
Building my own, is this a good deal on the parts?
Last response: in Windows 7
November 19, 2012 4:41:40 PM
Hello!
Can you tell me if this is a good deal im getting from Newegg?
Or if any of the parts will not work with another part provided.
And if you want, please tell me if I should get anything added to this!
Note: Total Prices Shown! Not Unit Price.
Quote:
NZXT Phantom 410 CA-PH410-G1 Gunmetal Steel / Plastic ATX Mid Tower Black Trim Computer Case Price: $99.99
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 15000) Desktop Memory Model CMZ8GX3M2A1866C9
Price: $48.99 (for one)
NOTE: I AM GETTING TWO OF THE ITEM LISTED ABOVE SO IT EQUALS OUT TO $97.98
ASRock Z77 Extreme4 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Price: $104.99
SAPPHIRE Vapor-X 100352VXSR Radeon HD 7950 3GB 384-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
Price: $329.99
CORSAIR Enthusiast Series TX650M 650W ATX12V v2.31 / EPS12V v2.92 80 PLUS BRONZE Certified Semi Modular High Performance Power Supply
Price: $109.99
Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
Price: $219.99
Seagate Barracuda ST31000524AS 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Price: $49.99
LG DVD Burner Black SATA Model GH24NS90 - OEM
Price: $18.99
Microsoft Windows 7 Professional SP1 64-bit - OEM
Price: $139.99
I AM GETTING TWO OF THE "CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 15000) Desktop Memory Model CMZ8GX3M2A1866C9" SO IT EQUALS OUT TO: $97.98 FOR THAT ONE ITEM!
Items that have money off is:
Before Price: $109.99
Before Price: $229.99
Before Price: $119.99
Before Price: $134.99
Subtotal (This is with the money off): $1,171.90
Before prices NOT included with subtotal.
I want to know, again.
Will these items work with eachother?
Anything you want me to add?
Should I get a wireless card? (ASUS PCE-N10 Wireless Adapter IEEE 802.11b/g/n PCI Express Up to 150Mbps Wireless Data Rates 64-bit WEP, 128-bit WEP, WPA2-PSK, WPA-PSK, WPS support)
Am I getting a good deal?
Colors are used for easy use
If this is posted in the wrong section, please move it/tell me! Thanks
Sorry for caps when used!
November 19, 2012 5:01:41 PM
Note: Added the "CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 15000) Desktop Memory Model CMZ8GX3M2A1866C9" Forgot to do that when I first posted it!
m
l
Best solution
November 19, 2012 5:22:56 PM
The bold/colors thing is relatively unreadable. It's easy enough for us if you put a line between each item.
The only big deal you're getting is on the hard drive - that's pretty cheap for 1tb. Windows licenses go cheaper than $140 for the oem version usually, and you can probably settle for home premium unless there is a specific feature with professional that you are wanting to pay extra for. Windows 7 Home Premium was around $80 on newegg at the Windows 8 launch.
Yeah, these days there's really no reason not to get a Wifi card, they're usually like $10 for the cheap ones and up to 30-50 for higher end ones.
November 19, 2012 5:25:43 PM
How about the wireless card should I get one? I might use wireless, unsure at the moment.
m
l
November 19, 2012 5:47:04 PM
Best answer selected by ElijahLee.
m
l
November 19, 2012 5:47:27 PM
Thanks, you are saving me some by telling me to go to WIN7 HOME
m
l
