HI,
I have had some HD's fall over and I was wondering how I can check the power supplies that come with the USB's.
Some of them are so similar in looks and plugs but I am not sure what belongs to what and I have about 12 of them.
I wopuld okie to check to see that the voltage etc., is right. Also
Is there a way to check the actual components inside a USB box, other than to try it out with a good drive and hope it doesn't trash it.
I have IDE and Sata boxes and because I had so many HD crashes caused by a bad mobo and power supply, I am not sure which usb boxes still work.
Thanks
oz
Thanks
oz
