T trainguy Honorable Nov 19, 2012 2 0 10,510 Nov 19, 2012 #1 how can I change the channel on my westell 7500 gateway to improve my wifi.
Solution das_stig Nov 20, 2012 Install inssider and see what channels are in use. http://www.metageek.net/products/inssider/download/ Then log into the routers web interface and change the channel number.
das_stig Glorious Jul 24, 2009 8,283 30 46,040 Nov 20, 2012 Solution #2 Install inssider and see what channels are in use. http://www.metageek.net/products/inssider/download/ Then log into the routers web interface and change the channel number. Upvote 0 Downvote Solution
T trainguy Honorable Nov 19, 2012 2 0 10,510 Dec 1, 2012 #3 Best answer selected by trainguy. Upvote 0 Downvote
