Archived from groups: rec.games.pinball (More info?)
I am in the painfully long process of refurbing an eight ball deluxe
machine. I am having some trouble with ordering parts. Seems as if
there are no corresponding numbers or the numbers do not match up with
what I need!
What I'm looking for is what type of Minipost do I need? The playfield
needs 3. The manual gives a part number of ASE-2836-2, but the posts I
rec'd seem way too large and also they have a black rubber around the
top. I've looked at pix online and it appears that the post I need is
more of a standard "spear-type" post.
I also am needing the 2 metal brackets located underneath the flippers.
The part number I have is for a buffer wire M-121-53 abd the part I
rec'd is a curved wire that will not fit in the area necessary.
Any assistance is greatly appreciated!!!
I will try to be of assistance with your EBD parts search. The parts
numbers you give are the same as in the manual. How far apart are the
holes in your playfield for the buffer wires? How high above the
playfield would the post they sent you be, once you screw them in? I
have the two buffer wires and one post with the proper white 5/16"
rubber on it. with it you could match it up to be sure you get the
other two correctly. I have an almost complete populated wired
playfield, so if you are interested in the parts above or any other
part of the playfield I might have, let me know. JUKEPIN
Jukepin
Thanks for the response.
Seems like the parts numbers in the manual never coincide with what you
really need.
The buffer wires I need are the two located underneath the bottom
flippers. The holes are approx 2 and 3/8" apart.
The posts I am not sure of. The ones sent by pin resource which matched
my parts# consist of a machine screw...above the nut it is 3/8" with a
black rubber piece around the top (grommet??) below the hex head is
about 3/4" with 3/8" being threaded. I hope this makes sense. I could
snap a picture if necessary.
I had thought the posts were spear shaped.
Please let me know!
Thanks
CD
Your buffer wire dememsion is correct. The post discription is not even
close. I have the wires and one post. They are the same as on my
keeper game. If interested in them E-mail me direct. JUKEPIN
Yeah, those parts would help.
While we are on the subject my EBD is also missing two of the stainless
steel thimble looking deviced that are attached to the plastics. I also
need one rectangular backing that mounts behind the deluxe targets. I
have 5 of them, need 1 more. Last but not least is a white collar that
goes with the ball gate assembly. I have one and need one more.
Those parts are all on my populated playfield. Click on the blue words
next to the date (Show options) then on (reply to author) on next page
to continue this discussion, as I don't think to many people are
interested in the particulars.
