G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
I have a Sopranos where I began having the weak flipper. I called Stern
and they immediately sent out some of the new switches. Very quickly I
should add.
Put the new switch in and noticed a slight improvement. Still not where
it was before.
What else could I be missing? What is the correct length that the
switch contacts should be apart?
I took the flipper coil and the sleeve is not cracked. Flipper Fuse was
okay.
should add.
it was before.
okay.
