Solved
Headphones + sound card
So I want to download flac music, and buy a nice par of headphones to start listening to high end music. I already have a HT Omega striker and I am very happy with it. My question is what headphones and would it be worth upgrading to a HT claro so that I have a headphone amp? How much of a difference do they make?
Thanks
3 answers Last reply Best Answer
More about headphones sound card
  1. Best answer
    i'd have to recommend the headphones i use.....audiotechnica ath-m50s. m50 is coiled cable, m50s is straight cable. they are studio headphones which means they are very balanced.
    you do not have to use an amp with them as they are low resistance, but getting a soundcard with an amp for the headphone jack will make them sound a little better than the great sound they give you without an amp.
    i have used mine unamped on my phone, mp3 player, laptop and pc....and amped out of my receiver. sounded great in every case.
    if you dont like audiotechnica, i heard sennheiser makes a nice product as well.
  2. Okay, thanks, I suppose I'll just stick with my striker for now than because I eventually plan on getting a home system with a receiver so I'll just have to make due until then. Again thank you
  3. Best answer selected by Delengowski.
Headphones Music Sound Cards Audio
