2 audio output, setting up which to use for which program
Last response: in Home Audio
- Hi, I have an MAD7950 3gb card which I use in my Mac Pro. It has 2 x mini display ports and a dvi output. I want to use all th Forum
- SolvedSetting up wireless router to work with modem which used to be modem+wireless router combo Forum
- SolvedSet up drive as MBR which lowered the volumne to 2tb want to convert to GPT to get the full 3tb Forum
- SolvedCan I set up two wifi adapters on a single computer and choose which connection to use for which task? Forum
- SolvedWhich Audio setting for headset? Forum
- SolvedWhich output to use Forum
- SolvedUse 2 audio outputs as surround sound Forum
- Which IC is best make a Good And Correct Pre-amplified audio output Forum
- I use BroadBand wirless modem in which4 output.3 computers are connected in 3 output and one extended to TP-LINK WIRELESS Forum
- Which program should I use to overclock my computer? Forum
- Which set up quicket for light office use. Forum
- SolvedWhich SSD should I use for boot up? Forum
- SolvedWhich Program to Use for Benchmarking? Forum
- SolvedI got 2 hard drives and i dont know which one i should use for system and which one for my stuff(games etc.) Forum
- SolvedOn my dell x51 motherboard which i have in a new case it has too fan hook ups should i use them? Forum
- SolvedNvidia GeForce GT 630M reaching up to 95 degrees, need easy to use software which can help manage my GPU (CPU if possible) Forum
- I have got a setting screen up which is blue and it has advance security boot but it does not say repair at every one I go on Forum
- Which parts to use for HTPC/Video Editing Set-up? Forum
- Hi I am running windows 8.1 I have 2 program's that I use they both come up with program stop responding please help Forum
- SolvedNeed audio set up for home use/occasional party Forum
- More resources
Read discussions in other Home Audio categories
