Problems booting from CD
Archived from groups: microsoft.public.windowsxp.general (More info?)
I am trying to get rid of an installed XP Pro bootleg software and
reinstalling a new copy of Windows XP Pro. I cannot seem to get my computer
to boot from one of my CDs. The bios has ATPI CD as the primare boot witht
he hard drive secondary and the 3.5 drive as third. My TDK RW drive is master
and I have a Memorex as a slave. Is there another way to accomplish what I
need to do?
7 answers Last reply
More about problems booting
  1. Archived from groups: microsoft.public.windowsxp.general (More info?)
    In article <E04A45CA-ADB0-46A9-9C7D-F688168C0DC5@microsoft.com>,
    SkipBisconer@discussions.microsoft.com says...
    > need to do?
    Most times the computer will display a line right after posting "press
    any key to boot from CD", if you don't press a key in X amount of time
    it will continue and boot from the next device.
    Do you see that?
    Does the new copy of XP Pro have the proper hologram on it? Meaning are
    you sure the new copy is legit/valid and is also bootable?
    spam999free@rrohio.com
    remove 999 in order to email me
  2. Archived from groups: microsoft.public.windowsxp.general (More info?)
    No that doesn't come up I get the Intel Logo then a blank cursor for a minute
    then boots right into windows.
    > > need to do?
    > Do you see that?
  3. Archived from groups: microsoft.public.windowsxp.general (More info?)
    In article <9FE01099-D6E1-4F9E-89CB-1F447FCB8A00@microsoft.com>,
    See if you can go into the BIOS and look for another place where it
    might have boot options - many of them have a BOOT tab, others have two
    places - where you specify boot order and then you have to specify
    another bootable drive.
    You might also disable the quick/quiet boot options so that you can see
    the POST.
  4. Archived from groups: microsoft.public.windowsxp.general (More info?)
    No other place to set boot sequence. I found on the Advance screen boot
    configuration but thats just a boolean question. I am wondering if I have to
    make my TDK slave and the Memorex Master ( this is a pain to do). What do you
    think?
    Can I just run setup in while in the old Windows and have it start from there?
    > the POST.
  5. Archived from groups: microsoft.public.windowsxp.general (More info?)
    > boot configuration but thats just a boolean question. I am wondering
    > if I have to make my TDK slave and the Memorex Master ( this is a pain
    > to do). What do you think?
    > from there?
    I'm sure you've tried this, but... put the XP cd in the other cd drive
    and see what happens.
    Malke
    Elephant Boy Computers
    www.elephantboycomputers.com
    "Don't Panic!"
    MS-MVP Windows - Shell/User
  6. Archived from groups: microsoft.public.windowsxp.general (More info?)
    > need to do?
    Hi Skip
    Check out Smart Boot Manager
    It will boot from a floppy and allow you to chose a CDRom to boot to
    among other things.(good for old bio's that don't have the boot to cd
    option)
    http://btmgr.webframe.org/
    Also you might run a disk cleaner on the cdrom drive
  7. Archived from groups: microsoft.public.windowsxp.general (More info?)
    Thanks for all your help. What eventually worked was I remove the case and
    unplugged the TDK RW (the master drive) which left the Memorex CD and then I
    was able to get the "Press any key to boot from a CD". Did a repair install
    with my new software and everything went great.
    > > need to do?
    > Hi Skip
    > option)
CD-Rom Windows XP
