Viewsonic E70fB monitor borad damaged
Last response: in Computer Peripherals
January 4, 2011 11:25:18 AM
my viewsonic E70fB monitor is not display.. black or with or blue screen.. no display. plz help me. some technitions seeing my monitor. he says monitor board damaged.. plz provide kit and replaced that.. thats all. i am in hyderabad, near yousuftuda check post.. suresh
edited to remove personal info
a c 105 C Monitor
January 4, 2011 3:37:27 PM
suresh,
if the technician said that the internal circuit board is damaged then you should have the technician either repair or replace the board. You could probably cross reference part numbers online but unless you are familiar with CRT monitors I do not suggest that you attempt this yourself.
if the cost of parts and service (which can be high) is more than you are willing to spend on an older monitor you might want to put the cash towards a new monitor.
filhart,
e70fb is a crt, not an lcd.
m
l
Anonymous
a b C Monitor
January 4, 2011 6:30:56 PM
"e70fb is a crt, not an lcd."
In which case he should definitely take it to a repair shop -- the inside of a CRT monitor is no place for unskilled hands.
m
l
