Elmo: Zone shortcut script doesn't work anymore
Archived from groups: microsoft.public.games.zone (More info?)
Hi Elmo,
I've been using the shortcut script to log on to the zone for a long time
and it's worked great (found at:
http://www3.sympatico.ca/nibblesnbits/ZonePassport.html
However, it doesn't work correctly now, (logging me on and leading me to my
preferred zone page).
Now I always get redirected to: http://login.passport.net/uilogin.srf
I have to enter my passport password.
It then sends me to this:
http://memberservices.passport.net/memberservice.srf?lc=1033
Then I have to manually go to the backgammon page.
I assume the Zone changed something in the last few days. Any suggestions
or changes to the script to get the 1-step action again?
Here's the script I'm using:
<script>done=0; function stop_cat() { if (!done)
{i.navigate("about:blank");done = 1;} else {done = 1;}}</script>
<IFRAME id=i src="http://msnialogin.passport.com/login.srf?&ec=e1"
onload="stop_cat()" width="0" height="0"></IFRAME>
<body onload="go_cat.submit()"><FORM name="go_cat" METHOD="POST"
ACTION="https://login.passport.com/ppsecure/post.srf?id=20960&ru=http://zone
..msn.com/en/backgammon/rooms_compete.htm">
<INPUT TYPE="hidden" NAME="login" value="MY PASSPORT EMAIL"/>
<INPUT TYPE="hidden" name="passwd" value="MY PASSWORD"/>
<input type="hidden" name="mspp_shared" value="1"/>
<input type="hidden" name="sec" value="0"/>
Gregg C.
17 answers Last reply
More about elmo zone shortcut script doesn work anymore
  1. Archived from groups: microsoft.public.games.zone (More info?)
    Gregg Cattanach wrote:
    > Hi Elmo,
    > Gregg C.
    Try logging in normally. If you get two popup windows, you need to get
    rid of the second one; it's messing up the script. It might help to
    open Internet Properties, Security tab, Sites, and add sas.zone.msn.com
    to the list of allowed sites.
    Please post whether this helps or not.
    +Elmo_Tech
    MSN® Gaming Zone™ - Technical Support
    clvck
  2. Archived from groups: microsoft.public.games.zone (More info?)
    Gregg, you're lucky I didnt copyright my email to Elmo
    a while back. Yours is a near exact duplicate of min with
    excepting that I used Spades instead of Backgammon. :-))
    Been happening (to me) since October or November !
    ELMO ! A bit more pertinent info on the subject.
    After logging in passport I click Spades Tourney Room in
    favorites and am taken there but the SIgnIn/SignOut icon
    does not appear, My nick does not appear in the #users
    online area and I receive a Tourneys require zone
    registered, SignIn/SignUp now message and button which I
    ignore. I click Support, change nick and the SignOut icon
    appears, above reads welcome MrSmartButt2U, you are among
    98765 users etc. Apparently I have been signed in all
    along but zone (usually, not always) is unaware of it.
    The few times when the script does work correctly seems to
    be when I later have problems like
    1. Go and stay red immediately after entering a spades
    tourney room (restart machine is only fix).
    2. Lobby.exe caused an invalid page fault in (usually)
    Riched20.dll. (Lobby Error = Undocumented Feature)
    3. I've tried repairing IE but still getting, for no
    apparent reason, IE has encountered an error, IE
    insists on closing regardless of the restart IE
    check box status.
    IE ERROR DETAILS !
    Problem involving IE and Ole32.dll (not in faultlog).
    Starts with C00000005 which if memory servers is an
    unhandled exception error involving access violation.
    >> Hi Elmo,
    lc=1033
    >> Gregg C.
    you need to get
    might help to
    sas.zone.msn.com
    >+Elmo_Tech
    >MSN® Gaming ZoneT - Technical Support
    clvck
  3. Archived from groups: microsoft.public.games.zone (More info?)
    "+Elmo_Tech" <elmogeek@iglou.invalid> wrote in message
    news:4093D8B6.342CBD46@iglou.invalid...
    > > Hi Elmo,
    time
    my
    suggestions
    > > Gregg C.
    > +Elmo_Tech
    > clvck
    I'm not exactly sure what you mean by 'log in normally', but I did the
    following:
    It looks like the Zone has it screwed up again in some way If I just start
    from scratch at www.zone.com it has me logged in to passport already (sort
    of): The passport icon says 'sign out' but it doesn't show my login name in
    the hello dialog. Then when I click through to get to competitive zone
    rooms, the page comes up that says I must sign in. When I click the link
    to sign in, it automatically goes back to the competitive room without
    asking me for my passport password and then does have me logged in.
    The script still does what I said earlier. I really miss the 1-step
    process. It looks like MSN definitely changed something in the last couple
    days.
    Also, lately Zone Friends comes up either painfully slowly, (takes many
    minutes to get logged on), or not at all. I assume this is server problems
    at MSN.
    Gregg C.
  4. Archived from groups: microsoft.public.games.zone (More info?)
    > > > Hi Elmo,
    > time
    > my
    > suggestions
    > > > Gregg C.
    > following:
    > days.
    > at MSN.
    > Gregg C.
    You might ask NibblesNbits if you see him in the Zone; he usually is.
    But if you're shown as signed in, click that link to "sign out". See if
    the Passport page is set to automatically log you in. If so, deselect
    that option (again). Also clear any Passport and Zone cookies.
    +Elmo_Tech
    clvck
  5. Archived from groups: microsoft.public.games.zone (More info?)
    > check box status.
    > IE ERROR DETAILS !
    > >> Hi Elmo,
    > lc=1033
    > >> Gregg C.
    > you need to get
    > might help to
    > sas.zone.msn.com
    Clear the Zone and Passport cookies in case they're damaged. Also clear
    the Cache and make sure the browser is set to check for new documents
    every time. I know that takes longer to load the page, but it might
    prevent you from keeping the same damaged document.
    With Win 98 you can run SFC and see if there are damaged files but I
    believe OLE files are supplied with IE, which you said you repaired.
    Did you check for viruses? They can cause similar errors.
    +Elmo_Tech
    clvck
  6. Archived from groups: microsoft.public.games.zone (More info?)
    Hi Elmo! :-)
    Yep, recent changes have broken the automatic Sign in
    script unfortunately. I'm going to wait a short while to
    see if they reverse the changes (as has happened before)
    before attempting to make changes to the current script.
    See you on the Zone!
    Jimmy.
    "+Elmo_Tech" <elmogeek@iglou.invalid> wrote in message news:4094634E.3263BDF1@iglou.invalid...
    | > > > Hi Elmo,
    | > time
    | > my
    | > suggestions
    | > > > Gregg C.
    | > following:
    | > days.
    | > at MSN.
    | > Gregg C.
    | +Elmo_Tech
    | clvck
  7. Archived from groups: microsoft.public.games.zone (More info?)
    "Jimmy S." <Private> wrote in message
    news:O16YTT$LEHA.2456@TK2MSFTNGP12.phx.gbl...
    > Hi Elmo! :-)
    > Jimmy.
    From this message it sounds like the problem is some change made at MSN, not
    any setup, etc. on my machine.
    Awaiting with bated breath for a new and improved script! Please let us
    know here when you have it.
    Gregg C.
  8. Archived from groups: microsoft.public.games.zone (More info?)
    Not long ago I kept getting Zsetup installation failed
    then realized my hrtbeat was corrupted and I repaired
    that. I think I was running noclone and several
    instances of c:\windows\downloaded program files\
    conflict.1 (1 thru 8) relating to zsetup (failed ?).
    I found most instances in the registry but hesitate to
    delete them as I'm not positive what I'd be doing.
    icon
    among
    to
    >> check box status.
    >> IE ERROR DETAILS !
    >> you need to get
    >> might help to
    >> sas.zone.msn.com
    damaged. Also clear
    new documents
    but it might
    files but I
    you repaired.
    >+Elmo_Tech
    clvck
  9. Archived from groups: microsoft.public.games.zone (More info?)
    > icon
    > among
    > to
    > >> check box status.
    > >> IE ERROR DETAILS !
    > >> you need to get
    > >> might help to
    > >> sas.zone.msn.com
    > damaged. Also clear
    > new documents
    > but it might
    > files but I
    > you repaired.
    Run Regedit and search for "\Conflict.". (That's \Conflict. without the
    quotes.) Delete any instance. The worst that could happen is that
    you'd have to reinstall Heartbeat.
    You can look at each reference to the Conflict folder and make sure it's
    related to Heartbeat before deleting.
    +Elmo_Tech
    clvck
  10. Archived from groups: microsoft.public.games.zone (More info?)
    Yes I have (regularly) virus scanned using AVG as well as
    scanned for trojans and/or keyloggers using tauscan and
    also run adaware pro and spybot !
    When I searched the registry for conflict they all did
    pertain to hrtbeat allthough not all of the entries
    referenced the .ocx directly.
    Dumb question !
    The first registry hit was conflict.8\hrtbeat.ocx in the
    inprocserver32 and toolboxbitmap32 subfolders of a clsid
    which has 9 folders under it (type lib, ver, control etc).
    Should I delete (each) clsid that contains a reference to
    \conflict. or only subfolder containing the reference ??
    I understand if you need more info, if so will you email
    me at Mplus_Zclown@yahoo.com OR my regular email which I
    hope you have a record of.
    Thanks in advance
    >-----Original Message-----
    >> damaged. Also clear
    >> new documents
    >> but it might
    make sure it's
    >+Elmo_Tech
  11. Archived from groups: microsoft.public.games.zone (More info?)
    > Dumb question !
    > Thanks in advance
    > >> damaged. Also clear
    > >> new documents
    > >> but it might
    > make sure it's
    I would try deleting the key where the data was referenced, ie, the
    folder that's open in the left pane when the \conflict. is highlighted
    on the right.
    +Elmo_Tech
    clvck
  12. Archived from groups: microsoft.public.games.zone (More info?)
    Hi,
    The script has been updated. :-)
    Cheers!
    Jimmy.
    "Gregg Cattanach" <gcattanach-SKIP-@prodigy.net> wrote in message news:G69lc.224$N95.188@newssvr32.news.prodigy.com...
    | > Hi Elmo! :-)
    | > Jimmy.
    | Gregg C.
  13. Archived from groups: microsoft.public.games.zone (More info?)
    The script I find at this page:
    http://www3.sympatico.ca/nibblesnbits/ZonePassport.html is identical to the
    one I had before and still doesn't work (as described in my previous posts.)
    Where has the script be updated??
    Gregg C.
    news:usYLvK9QEHA.556@tk2msftngp13.phx.gbl...
    > Hi,
    > Cheers!
    > Jimmy.
    > | > Hi Elmo! :-)
    > | > Jimmy.
    not
    > | Gregg C.
  14. Archived from groups: microsoft.public.games.zone (More info?)
    Gregg,
    I found the new one at http://nibblesnbitspassport.tk/
    Regards...
    news:_Zjtc.1161$n65.756@newssvr33.news.prodigy.com...
    the
    posts.)
    > Gregg C.
    > > Hi,
    > > Cheers!
    > > Jimmy.
    > > | > Hi Elmo! :-)
    > > | > Jimmy.
    MSN,
    > not
    us
    > > | Gregg C.
  15. Archived from groups: microsoft.public.games.zone (More info?)
    It's available there or directly from:
    http://mvps.org/nibblesnbits/ZonePassport.html
    I'll make sure the Sympatico mirror gets updated tonight. :-)
    Cheers, Windows XP MVP Shell / User
    Jimmy S. http://mvp.support.microsoft.com
    Game FAQs: http://support.microsoft.com/default.aspx?scid=FH;[LN];gms
    Visit my Zone.com / Gaming Helpsite: http://nibblesnbits.tk or Call / Contact
    MS Support at: http://support.microsoft.com/default.aspx?scid=sz;en-us;top
    My advice is donated "AS IS" without warranty; nor do I confer any rights.
    _________________________________________________________
    "Ot" <uraza@tds.invalid (use net)> wrote in message news:%23pFNVS%23QEHA.2404@TK2MSFTNGP11.phx.gbl...
    | Gregg,
    | Regards...
    | the
    | posts.)
    | > Gregg C.
    | > > Hi,
    | > > Cheers!
    | > > Jimmy.
    | > > | > Hi Elmo! :-)
    | > > | > Jimmy.
    | MSN,
    | > not
    | us
    | > > | Gregg C.
  16. Archived from groups: microsoft.public.games.zone (More info?)
    Thanks for working it out, that works well. The only thing that would be
    nice to change is you always get this message "The web page you are viewing
    is trying to close this window. Do you want to close this window?" The
    answer is always yes, of course. Is there a way to skip answering this
    question?
    Gregg C.
    "Jimmy S." <Private> wrote in message news:40b61639$1@usenet01.boi.hp.com...
    Contact
    rights.
    > | Gregg,
    > | Regards...
    to
    > | the
    > | posts.)
    > | > Gregg C.
    > | > > Hi,
    > | > > Cheers!
    > | > > Jimmy.
    > | > > | > Hi Elmo! :-)
    > | > > | > Jimmy.
    at
    > | MSN,
    > | > not
    let
    > | us
    > | > > | Gregg C.
  17. Archived from groups: microsoft.public.games.zone (More info?)
    Glad you like the new script.
    The close window message might be removed in a futur release. :-)
    "Gregg Cattanach" <gcattanach-SKIP-@prodigy.net> wrote in message news:KuGtc.1575$n65.1239@newssvr33.news.prodigy.com...
    | question?
    | Gregg C.
    | Contact
    | rights.
    | > | Gregg,
    | > | Regards...
    | to
    | > | the
    | > | posts.)
    | > | > Gregg C.
    | > | > > Hi,
    | > | > > Cheers!
    | > | > > Jimmy.
    | > | > > | > Hi Elmo! :-)
    | > | > > | > Jimmy.
    | at
    | > | MSN,
    | > | > not
    | let
    | > | us
    | > | > > | Gregg C.
Video Games
