Archived from groups: microsoft.public.windowsxp.general (More info?)
I have a weird situation with XP Home edition; SP2 is NOT installed:
System:
XP Home on an eMachines T2742 (2.7 GHZ; 256 Mb RAM; 40 Gb HDD)
Problem:
Boots to Welcome screen and loops back to welcome screen when any of the
UserID buttons are clicked. Ctl-Alt-Del brings up the Classic login dialog
box, but still loops back to XP Style Welcome screen when attempting to log
in from the Classic dialog. Cannot circumvent the boot sequence, nor get
past the Welcome screen to get to any desktop functions in XP.
What I Tried:
F8 out of startup sequence to safe mode - same thing
F8 out of startup sequence to command prompt mode - same thing
F8 out of startup sequence to last known good config - same thing
F8 out of startup sequence to debug mode - same thing
F8 out of startup sequence to boot logging mode - same thing
Checked the CMOS settings for odd power or video settings - all default
settings appear correct.
Hi
If none of those options allow you access to Windows, you can try a 'Repair'
install of XP. Please have a look at the following article by Michael
Stevens:
Will Denny
MS MVP Windows Shell/User
Please reply to the News Groups
"Jim Lake" <jimlake@easynews.com> wrote in message
news:rYVTe.308171$WN5.119850@fe02.news.easynews.com...
> System:
> Problem:
> log
> What I Tried:
> Can anyone help with a solution please?
> JL
Does eMachines provide an XP CD so the OP can do a repair install?
Alias
"Will Denny" <willdenny@mvps.org> wrote
> Hi
> 'Repair' install of XP. Please have a look at the following article by
> Michael Stevens:
> "How to Perform a Windows XP Repair Install"
> http://michaelstevenstech.com/XPrepairinstall.htm >
> Will Denny
>> System:
>> Problem:
>> dialog
>> log
>> What I Tried:
>> JL
> System:
> Problem:
log
> What I Tried:
> JL
This usually happens after some imaging operation, e.g. with Ghost,
or when additional disks with WinXP on them are installed. It is
caused by the system drive letter being incorrect, thus preventing
WinXP from locating userinit.exe.
Hi
Some OEM CDs do have a 'Repair' option - if that's what the OP has.
Will Denny
"Alias" <aka@[notme]maskedandanonymous.org> wrote in message
news:%2370XkEHtFHA.236@TK2MSFTNGP11.phx.gbl...
> Alias
>> Hi
>> Michael Stevens:
>> http://michaelstevenstech.com/XPrepairinstall.htm >>
>> Will Denny
>>> System:
>>> Problem:
>>> dialog
>>> log
>>> What I Tried:
>>> JL
"Pegasus \(MVP\)" <I.can@fly.com> wrote in
news:eOzQRJHtFHA.3548@TK2MSFTNGP11.phx.gbl:
Thanks so much for your responses.
The system has an OEM eMachines version of XP HOME with a three disk set
and does not allow for a repair. The machine is not networked, I do have
access to another XP desktop that is the PROFESSIONAL version across the
street.
In examining the autoexec.bat file I see that it is using ghost to do the
re-imaging, and it issues a warning that all data will be lost.
It's either a re-install or boot to the A: drive. When I boot to the A:
drive I cannot see or change directories to the A: drive. I'll follow the
links provided to see if there are any other avenues, or if you bright
folks figure out anything that may be helpful it would be greatly
appreciated.
Thanks so much,
JL
>> System:
>> Problem:
>> the UserID buttons are clicked. Ctl-Alt-Del brings up the Classic
>> login dialog box, but still loops back to XP Style Welcome screen
>> when attempting to
> log
>> get past the Welcome screen to get to any desktop functions in XP.
>> What I Tried:
>> default settings appear correct.
>> JL
> The cure depends on your facilities. Is the machine networked?
> Do you have access to another WinXP desktop? See also here:
> http://support.microsoft.com/default.aspx?scid=kb;[LN];249321
"Lurker" <lurker@hotmail.com> wrote in message
news:I%YTe.312849$WN5.248778@fe02.news.easynews.com...
> street.
> appreciated.
> Thanks so much,
> JL
> >> System:
> >> Problem:
> >> when attempting to
> > log
> >> What I Tried:
> >> JL
I'm afraid this is going to be rough ride, as you will have to modify
the registry without having the benefit of a graphical user interface.
1. Accept the suggested NT partition.
2. Accept the full path to the registry directory.
3. Type system when prompted
4. Type 9 (for Registry Editor)
5. Type ? (to see the available commands)
6. Type ls (to see the current keys)
7. Type cd MountedDevices (it's case-sensitive!)
8. Type ls (to see the current values)
9. Type dv \DosDevices\C:
10. Repeat steps 8 and 9 until you have deleted all values
that look like this: \DosDevices\X: where X is any letter
of the alphabet.
11. Type q {Enter}, then q {Enter} again
You will be prompted to save or discard your changes.
news:#wrU7$NtFHA.2592@TK2MSFTNGP09.phx.gbl:
>> set and does not allow for a repair. The machine is not networked, I
>> do have access to another XP desktop that is the PROFESSIONAL version
>> across the street.
>> the re-imaging, and it issues a warning that all data will be lost.
>> A: drive I cannot see or change directories to the A: drive. I'll
>> follow the links provided to see if there are any other avenues, or
>> if you bright folks figure out anything that may be helpful it would
>> be greatly appreciated.
>> Thanks so much,
>> JL
> Boot your machine with a floppy boot disk from
> http://home.eunet.no/~pnordahl/ntpasswd/bootdisk.html > then do this:
> of the alphabet.
> I expect that this will fix your problem.
Dude, thanks so much for your help. I'll give this a whirl this morning.
I've been pounding it hard on a network where the users are disabling the
firewall because it won't let them receive files from their buddies.
Sometimes USER is really a four letter word!
Thanks again to all who have responded with their helpful advice!
news:4A9Ue.269889$Jd.220530@fe11.news.easynews.com...
> >> across the street.
> >> Thanks so much,
> >> JL
> > http://home.eunet.no/~pnordahl/ntpasswd/bootdisk.html > > then do this:
> > of the alphabet.
> JL
