Need some advice. My motherboard is a GIGABYTE GA-P67A-UD4-B3 LGA.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128478&Tpk=N82E1681312847
It's suppose to support 7.1 surround sound. I am using turtle beach PX500 head set that also supports 7.1 surround sound. My problem is this, when I go to change my audio settings on my pc to 7.1 instead of 5.1 the option isn't there. I'm connecting the PC to the headset transmitter via the optical jacks.
I have read several places that optical just doesn't support 7.1 and I've read that it does other places. So that might be the problem. If that is the problem then:
A. Is it safe to assume that 7.1 is only meant to be connected with multiple 3.5mm jacks?
B. How should I go about utilizing the 7.1 surround sound? It only has the generic red and white jacks other than the optical.
