Archived from groups: alt.sys.pc-clone.dell (
More info?)
"Chuck Lapre" <chuck@nospam.org> wrote:
>Thanks for the help! You learn something new everyday!
In XP, if the Add/Delete entry for an already deleted program
still exists [e.g., you used the app program's undelete rather
than XP's add/delete], and you try again to delete the program
using the XP Add/Delete, it will tell you that the program has
already been deleted, and ask if you want to remove that
program's XP Add/Delete entry. Say yes, and it disappears.
Presumably this will save having to go in to the registry to find
the applicable add/delete program entry and remove it, since
you've used XP itself to make the removal.
OJ III
[Email to Yahoo address may be burned before reading.
Lower and crunch the sig and you'll net me at comcast.]
