Problem with level in one channel on mackie vlz pro 1202
Last response: in Home Audio
January 30, 2012 2:50:33 PM
Hello, like the title says I have a problem with the level on the first channel of my mackie mixer.
It is a mono channel and when I plug an instrument it makes practically no sound, even if the pot is turned on the max level, I Turn the trim pot on maximum level and the sound is preceptible but softer than the other channels, maybe is a problem of the amp section of the channel?
thanks!
February 3, 2012 12:27:35 PM
A blown op amp in that channel.
February 3, 2012 6:44:06 PM
I imagined that, I will try changin the amp
thanks
