The printer won\'t print makes a grinding sound
Last response: in Computer Peripherals
January 25, 2011 11:02:50 AM
The HP PSC 2175v printer quit printing. Makes a grinding thumping sound and the and it won't print. What should I do?
January 25, 2011 3:32:09 PM
The carousel/feeder is powered by a transmission belt. It is likely that the belt's teeth are grinding on the cogwheel( or it could be the 2 cogwheels grinding). Time to replace the printer. These components are made of plastic and almost designed to fail after a while, so consumers need to go and buy another one.
m
l
January 25, 2011 8:50:03 PM
Thanks for your wise answer. I appreciate your promptness and am leaving to go buy one right now.
m
l
January 25, 2011 10:11:38 PM
No problem; printers die, like everything else made by man. Good luck with your new one.
m
l
