P4 2.8 - 3.0 speed difference
nico3d
44
On the same system, same settings, how much faster (in percentage) is a P4 3.0 Ghz than a P4 2.8 ?
Nico -- Nick :p
Spitfire_x86
Splendid
Jun 26, 2002
7,248
Not noticable
<b><A HREF="http://geocities.com/spitfire_x86" target="_new">My Website</A></b>
<b><A HREF="http://geocities.com/spitfire_x86/myrig.html" target="_new">My Rig & 3DMark score</A></b>
G
Guest
Guest
7% for any benchmark that scales perfectly with clockspeed; that means almost not a single real world app. Roughly half that, or less in most actual applications. In games, likely close to 0% unless you play in 640x480
= The views stated herein are my personal views, and not necessarily the views of my wife. =
JLacey64
35
very tiny amount of difference between the two.
maybe just 2-5% faster.
<b><i>"The Past Is Over;
A New Beginning"</i></b>
nico3d
44
so now, let me ask you this....
I have a P4 2.53ghz 533 FSB(no HT) running on asus P4G8X
Now I plan to move to a 3.06 ghz 533FSB (with HT)....since, I dont'have money enough to get a new motherboard that supports 800 FSB together with the processor. So I have to stick to the 533FSB line.
So my question is. Will there be a worthy difference between my 2.53 (no HT) and a 3.06 with HT ?
does my investment worth it?
Nico -- Nick :p
endyen
Splendid
Neither the HT nor the 20% increase in speed will help that much. Memory is the bottleneck in your current system. Since asus marketed that board as a good ocer, that may be your best route. If you can get your fsb to 158 with your current chip you will have the same speed as the 3.06 but will have much better perf. and that on pc2700.
G
Guest
Guest
Wait for Feb 2nd price cut on CPUs from intel.
Maybe youll be able to afford a 2.4c with the mobo after the price cut...
ytoledano
974
2.4C's are already at the same price level as 2.6C and they're going to stay there.
Got a nice overclocked overvolted system to keep you warm at night? That's great. Guess I'll have to settle for a woman...
Spitfire_x86
Splendid
Jun 26, 2002
7,248
It's wiser to wait and replace both CPU+MB later.
No matter when you upgrade, you should get something like Athlon64 3400+ or faster to get some real performance boost.
sirak
341
If I were you, I would hold out for the Prescott or for the A64s to get cheaper. Your processor is hardly weak.
PIV 2.4c @ 2.89ghz
1gig PC3200 (512mbx2)
ASUS P4P800
GF3 Ti200 64mb (soon to be replaced)
WinXP Pro
3DMark2001SE: 6300
3DMark2003: 688
