G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
Please help I'm getting frustrated.
My CV is acting very strange. The problem originally occurred last
year, then I had to put the game in storage because I was moving and
now I finally got it set up again.
This is what happened when the problem first came up.
I was in the middle of a game and everything was going well, and during
Highwire Multiball one ball drained down the right outlane and all of a
sudden the game went into a ball search mode and the display read the
following.
Testing Ringmaster
Motor Drive:
Position Switches:
Direction Drive
Coin Door Open
After trying to find the problem I noticed that the 2803 IC and the
R127 resistor got fried so I sent the CPU Board down to Clive at the
Coin-Op Cauldron for his services. By the way he's great to do business
with, mighty quick turnaround.
Now I installed the repaired board, turned on the game, seemed to boot
up fine, had a couple switch errors, and when I closed the coin door
the DMD went blank for a few seconds then the following message
appeared on the display.
Check Fuses F106 & F101
Well I checked them and they're fine. If I re-boot the game it will do
the normal startup then give me the same Check Fuses error.
Now I can't even go in to test mode, I'm just kind of locked up in this
mode. Also, when I hit the test switch on the coin door after a
re-boot, I got the message
Check Fuse F101 and F109, J127 and Opto 12V Supply.
I'm no whiz at repairs can handle minor issues, but this one is way
over my head.
Anyone who can help I'd be really appreciative.
BTW, I live in Havertown, PA Delaware County
following.
Testing Ringmaster
Motor Drive:
Position Switches:
Direction Drive
Coin Door Open
over my head.
