G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
Problem 1
The sound on my newly acquired black hole (lucky #10 ) is working
but:
Sound is low and if I turn the volume up, there's no real gain until I
hit the MAX , then there's a BIG DIFFERENCE and is WAY too loud.
I've tried playing with the pots (R16 & R15), it's making a little
difference but not enough (for me) to be ok to play and enjoy the
sounds.
My next step is to change the volume pot in the coindoor. Is this a
good assumption ? I'm reading Clay's guide on it and it seems I should
be happy to have sounds at all !
Problem 2
I never thought I would say this about a gottlieb but MAN those
flippers are powerfull ! Is this normal ? The middle playfields
slings are also very powerfull ?
thanks
Phil
http://mrhide.pinnesota.org/gallery/blackhole
Problem 1
but:
sounds.
Problem 2
thanks
Phil
