G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
My Mousin' Around which has been in in storage and is now being resurrected
has a problem with the left flipper.
It's completely dead BUT... with the glass off, if you press the left flipper
button and lift the flipper with your right hand you can tell it's trying to
work and if you help it a little it seems to want to jump at the very end of
its stroke.
All the mechanical parts are clean and not worn and the tolerances/gap
between the PF and flipper are good so there is no binding.
I've checked all the mechanical connections like the wiring to the solenoid,
the backbox connections, and the flipper switch (of which I've filed the
points).
As a start I was just going to just replace the transistor that controls it
to see if that would work but for the life of me I can't find it or much
about the flippers in the schematics (which I'm poor at).
Any ideas?
Thanks.
Ron -- CARGPB7
ronstr@comflycast.net -- remove the "fly" to email
its stroke.
points).
Any ideas?
Thanks.
Ron -- CARGPB7
