Battery ASUS ZenBook UX31E Problem
Hi!
I have the following problem:
After 3 years, the battery of my ASUS ZenBook UX31E given up the ghost and I've bought a new (not a replica but the original model purchased from http://www.comprarbateria.es/asus-zenbook-ux31e.html ).
The battery can be used easily and is also recognized by the system.
Only problem: He can not be charged.
When you first insert the battery was at 33%. In network mode, it remains at 33%. However, it is shown: left 33% (network operation is not recharged).
Have already taken out the battery again and blown onto the contacts and everything wiped cloth with NEM (thought it might be a bit dusty). But nothing helps.
Can someone help me? Were so thankful for every tip.
Read more: http://www.comprarbateria.es
1 answer Last reply
More about battery asus zenbook ux31e problem
  1. Tips on ASUS Zenbook UX31E Battery:
    Do not remove the ASUS ZENBOOK UX31E Laptop Battery Pack from the device if you are not going to use it instantly.
    Do not modify or disassemble rechargeable Asus laptop batteries.
    Avoid short circuit of the terminals by keeping your ASUS Zenbook UX31E Battery laptop, away from metal objects such as necklaces or hairpins.
    100% compatible with original laptop.
    Do not expose the battery to water or other moisture or rain.
    Do not incinerate or expose battery for ASUS Zenbook UX31E notebook to excessive heat, which may result in an exposure.
Configuration Battery Asus Windows 7
