Archived from groups: microsoft.public.broadbandnet.hardware (More info?)
actually the solution is just the opposite. you need to uninstall the
Broadband Networking Utility and use Windows XP's built in wireless zero
configuration feature to configure and manage your wireless card. if you
need to manage a Microsoft base station, use a web browser
http://192.168.2.1
the BNU is really only for non XP computers. it does not offer WPA security.
John Singel wrote:
> If you've installed SP2 and find your MSBN wireless no
> longer works (apparently a lot of people have had the
> problem) try the following:
> 1. Click Start.
> 2. Right-click My Computer.
> 3. Click Manage.
> 4. In Computer Management, double-click Services and
> Applications.
> 5. Then click Services.
> 6. Right-click Wireless Zero Configuration,
> 7. Then click Properties.
> 8. In the Startup type box, click to select Disabled.
> 9. Then click OK.
> 10. Close Computer Management,
> 11. Then restart the computer.
> It worked for me, maybe it will work for you as well.
Thanks John,
I tried your fix and all is well now. Apparently the wirless zero config
service was conflicting with the BNU.
I attempted to try the "don't use the BNU method" by telling msconfig not to
start the utility and still could not configure using the wireless setup
utility in SP 2. It would not let me complete the configuration....
"John Singel" <anonymous@discussions.microsoft.com> wrote in message
news:097901c48ea8$5f576730$a401280a@phx.gbl...
> 1. Click Start.
> 3. Click Manage.
> Applications.
> 9. Then click OK.
Yeah, but just recently there was a software upgrade on
this site which was specifically described to prepare our
existing Microsoft-hardware wireless networks to be ready
for SP2.
I spend many hours wrestling with the over the weekend (as
I'm sure thousands of others did) before finally removing
SP2, and I would have to say there is no excuse for
Microsoft releasing SP2 and having it incompatible with
their own hardware.
So there.
>-----Original Message-----
uninstall the
in wireless zero
wireless card.
> Barb Bowman
> Expert Zone Columnist
> http://www.microsoft.com/windowsxp/expertzone > MS-MVP (Windows)
So Microsoft, which is it? The BNU or wireless zero?
Will wireless zero also tell you when your basestation
needs a firmware update like BNU does?
>for SP2.
(as
>their own hardware.
>So there.
>uninstall the
>in wireless zero
>wireless card.
>> Barb Bowman
>> http://www.microsoft.com/windowsxp/expertzone >> MS-MVP (Windows)
uninstall the
in wireless zero
browser
>http://192.168.2.1
offer WPA security.
>> 1. Click Start.
>> 3. Click Manage.
>> Applications.
>> 9. Then click OK.
> Barb Bowman
>For those of us who'd rather not mess with things that we
don't fully understand and as result could ultimately
cause us a lot more grief, is Microsoft going to come out
with a patch?
Look, you can *run* the NEW BNU, but don't use it to configure your wireless
card. Use XP to do this. But if all you are running it for is to be notified
of upgrades, just drag it out of the startup group onto your desktop and run
it once a month or so.
The issue is that the BNU should not be used to configure a wireless card IF
you are using XP.
>> for SP2.
> (as
>> their own hardware.
>> So there.
>>> the Broadband Networking Utility and use Windows XP's built in
>>> wireless zero configuration feature to configure and manage your
>> wireless card.
>>> Barb Bowman
>>> http://www.microsoft.com/windowsxp/expertzone >>> MS-MVP (Windows)
It definitely is compatible.
<anonymous@discussions.microsoft.com> a écrit dans le message de news:
2f4d01c48ec3$8bd97df0$a301280a@phx.gbl...
> for SP2.
> their own hardware.
> So there.
> uninstall the
> in wireless zero
> wireless card.
>> Barb Bowman
Look, they probably won't. As everyone's been trying to tell everyone else
THERE'S NO NEED FOR THE BROADBAND UTILITY IN XP except if you want to check
for updates, which you can do manually via the web or by running the Utility
once every few weeks or so.
I don't understand your logic... if you're having trouble with something,
*why* are you afraid of doing a fix that everyone that knows more than you
is telling you will work? Do you think you'll "break it more"?
Just try it - it works.
"martyv" <anonymous@discussions.microsoft.com> wrote in message
news:2f7201c48ec6$6c108fb0$a301280a@phx.gbl...
Barb,
Thanks for your suggestions. I used the wireless zero tool to configure the
MN-510 and dragged the BNU icon from the startup folder to the desktop and
the whole system seems happy now. I must say that that I had to explore a
bit to figure out how to launch the config tool. After I discovered that it
was a simple right click and view available wireless networks I felt rather
dumb. At any rate thanks again for your help and patience.
Michael
"Barb Bowman (MVP-Windows)" <barb@nospam.com> wrote in message
news:%23HxA1isjEHA.1040@TK2MSFTNGP10.phx.gbl...
> wireless card. Use XP to do this. But if all you are running it for is to
> be notified of upgrades, just drag it out of the startup group onto your
> desktop and run it once a month or so.
> IF you are using XP.
>>> for SP2.
>> (as
>>> their own hardware.
>>> So there.
>>> wireless card.
>>>> Barb Bowman
>>>> http://www.microsoft.com/windowsxp/expertzone >>>> MS-MVP (Windows)
> Barb Bowman
remove the BNU utility from the startup group by dragging it from the
programs menu, startup to your desktop.
exit the BNU if it is running bu right clicking the icon in the
notification area.
download and apply SP2 from windows update or autoupdate
after SP2 reboots, install the MSBBN update you downloaded
delete the shortcut you dragged to your desktop
decide whether or not you want to always run the BNU (but use windows
to configure your wireless adapter and not the BNU). if you don't want
to always run it, drag it from the startup group to your desktop
On Mon, 30 Aug 2004 19:55:04 -0700, "Paul Allen \(but not the ex-ms
one...\)" <anonymous@discussions.microsoft.com> wrote:
>Barb,
>So, help thousands of us out here. We have existing
>wireless networks running on XP that we set up with the
>Microsoft Broadband Network Utility.
>We now need to install SP2.
>OUR QUESTION: What do we do, and in what sequence?
>Thanks, and if you get around to answering this, please
>ask Microsoft to put it on the website!
>Paul
yeah this isnt right i never used the dumb wireless
management software that came with the card even when i
was running sp1 so know i have sp2 and i loose network
connectivity every few seconds and sometimes my system
lags bad, and when i loose connectivity i run ipconfig and
get a paragraph of text saying to call their support line
and something about an unknown error code. the funniest
part is that it runs better under linux!
>for SP2.
(as
>their own hardware.
>So there.
>uninstall the
>in wireless zero
>wireless card.
>> Barb Bowman
If you're not using WPA, make sure you turn off the 802.1x Authentication in
the Properties of your LAN connection.
Chris H.
Microsoft Windows MVP/Tablet PC
Tablet Creations - http://nicecreations.us/ Associate Expert
Expert Zone - www.microsoft.com/windowsxp/expertzone
news:5c5101c491fe$29b05840$a601280a@phx.gbl...
>>for SP2.
> (as
>>their own hardware.
>>So there.
>>uninstall the
>>in wireless zero
>>wireless card.
>>> Barb Bowman
