Tech Bally Mr & Ms Pac-Man MPU problem
Archived from groups: rec.games.pinball (More info?)
I have a Bally Mr & Ms Pac-Man Pinball and it will not hold memory. The
battery has been replaced and the board cleaned so thats not the issue I
don't think. For some reason I can set settings and clear bookkeeping but It
will not remember anything I have done. If I let it sit a short time and
turn it back on everything I have changed is gone and it will add
bookkeeping amounts from out of the blue. Have no idea what else it could be
any help would be great!
Also I have a baby pac-man doing sort of the same thing. I will clear the
High scores and bookkeeping and they will come back. Sometimes the high
scores have numbers in them that should'nt be there like a 2 at the end.
Nothing scores 2 points on this game. Also the intials for the high scores
have numbers in them and you can only add letters for the high score so not
sure whats up with that either. Let me know if anyone can help
Bud
4 answers Last reply
More about tech bally problem
  1. Archived from groups: rec.games.pinball (More info?)
    Try measuring the voltage at the 5101 (U8) pin 22 when the machine is
    turned -off-. Should be about 3.6 volts.
    Check connections at R12 and the batteries. And as other poster said -
    verify polarity of the batteries.
    -- Ed
    "Bud Klass" <budklass@sprynet.com> wrote in message
    news:UDTJe.5371$ns.5042@newsread1.news.atl.earthlink.net...
    > It
    > be
    > not
    > Bud
  2. Archived from groups: rec.games.pinball (More info?)
    Just a thought, but are you sure you have the polarity of the batteries and
    the diode-protected battery pack correct on the MPU board? And are the
    batteries confirmed to be fully charged (with a meter or battery tester)?
    The jumbled high scores on BPM are the result of not saving your real high
    scores with your battery backup. They can be reset through the on-screen
    menus and will fill up with the correct scores as you play the game.
    Hope this helps.
    > It
    > be
    > not
    > Bud
  3. Archived from groups: rec.games.pinball (More info?)
    Ed, thanks for the help here is what I came up with.
    The batteries are reading about 4.8 volts at the neg on the board and before
    the diode thats installed between the pos wire going to the board. After the
    diode at the board its reading 5.39 volts this is with the power on. I had
    these boards repaired by someone and the put a 3 aa battery holder with two
    leads going to the board with a diode between the Pos wire going to the
    board and going back to the battery holder. Does all this sound right? I
    think its a N4001 diode with the band toward the battery holder. Let me know
    if all seems right because its still not working right,
    Bud
    "GPE" <See_my_website_for_email@cox.net> wrote in message
    news:Z5UJe.306$U92.258@okepread06...
    > -- Ed
    but
    > > It
    could
    > > be
    the
    scores
    > > not
    > > Bud
  4. Archived from groups: rec.games.pinball (More info?)
    Bud,
    Regarding "4.8 volts at the neg" part of it. I'm not sure you mean by that.
    Did you measure any voltages with the machine turned off? With meter ground
    lead to ground and meter positve lead to pin 22 of the 5101?
    You have the diode on the positive lead of the battery holder - as expected.
    This means you are using non-rechargeables (i.e. Alkaline's). To do this,
    the 1N4001 blocking diode must have the band oriented towards the CPU board
    and away from the battery holder -- and must be on the battery holder's
    positive lead.
    -- Ed
    news:RFeKe.5884$ns.5685@newsread1.news.atl.earthlink.net...
    > before
    > the
    > two
    > know
    > Bud
    >> -- Ed
    >> > I
    > but
    >> > It
    >> > and
    > could
    >> > be
    > the
    >> > end.
    > scores
    >> > not
    >> > Bud
Games Video Games
