CQ60,Max hard drive size,NEED HELP.
Hi, Am hoping someone will know the answer to my question, I have a Compaq Presario CQ60-405SA laptop and i need to know what is the maximum size hard drive i can fit to it as i need lots off space for my bits, AM hoping its at least 320gb as i have just ordered one before thinkng . Please help if you can.
Thanks in advance,
Chris.
1 answer Last reply
More about cq60 hard drive size need help
  1. You can go as big as you want, just as long as the new drive is compatible connection and size wise, i.e. I believe yours is SATA I and is probably 2.5 inches.
Hard Drives Laptops
