Archived from groups: microsoft.public.windowsxp.general (More info?)
OK! This may be something someone has previously described
before, but I can't resolve it. I am running Windows XP and
have all the updates. When I open a folder, I can not get
the stupid software to save my preferred settings for the
folder. I desire to have the address bar appear in the
header of the folder.
I have opened the "View" menu a hundred times, click
"Toolbars", and click "Address Bar" so that the check mark
appears. I then click "Lock the toolbar" so that the check
mark appears. I then open the "Tools" menu, click the
"Folder Options" tab, click the "View" tab, and click "Apply
to All Folders". Then I click "Ok", close everything,
reboot, and I'm back to square one with no address bar
visible in the folders.
Does anyone understand why this happens? Can anyone propose
a solution?
Many thanks for your assistance. I suspect that it
something simple, but I am at a loss as to how to resolve
the dilemma.
Although i don't know exactly why it would be doing this, i think it
wouldn't be a bad idea to create another account with the same privledges
(which must be administrator to make account). Then see if it works for them
If it does than make a backup of ur user docs and settings and delete ur
user, then re-add your user
I can't and won't guarrentee this to work but it would be what i'd do
Good in Home Networking, XP Home based problems, and Pro based Problems
Add my email to MSN Messenger if u wish
jayso_chinnery@spamfreehotmail.com.au (remove spamfree)
"Regnad Kcin" <NickDanger@ThirdEye.net> wrote in message
news:iK5Ve.35983$1g2.22298@fe05.lga...
> a solution?
> the dilemma.
> Please email me at nospam1953@bellsouth.net.
