Archived from groups: microsoft.public.windowsxp.general (More info?)
Sorry to have to post this again, but no-one seems to want to answer this
question.
Can someone please help or direct me where I can get some answers.
Whenever I put certain cd's in my cd rom my pc loses all power,
when I try to turn it back on , it starts up but I get a blank screen. I then
have to turn it off at the wall and turn it on again.
I have cleaned the fan and inside the machine. I haven't changed anything or
installed new software, all these discs previously worked.
Any help would be appreciated.
> this question.
> screen. I then have to turn it off at the wall and turn it on again.
> anything or installed new software, all these discs previously worked.
No one wants to answer?
You put in a CD and your computer loses all power.
Replace the CD drive with a different one - try again.. If it still does it,
then you may have a bad controller (on the motherboard) or a bad power
supply.
"Shenan Stanley" <newshelper@gmail.com> wrote in message
news:esBAic1tFHA.464@TK2MSFTNGP15.phx.gbl...
want to answer
| > this question.
some answers.
all power,
blank
it on again.
changed
previously worked.
it still does it,
a bad power
| supply.
| Shenan Stanley
| MS-MVP
| How To Ask Questions The Smart Way
| http://www.catb.org/~esr/faqs/smart-questions.html |
OK, it loses power when I put Sim City 4, The Sims 2 and a Windows XP PC
basics disc (from a mag) in. But then it works when I put Roller Coaster
Tycoon 3 and a Netguide cd (from a mag) in. I haven't obviously tried all my
cd's as I have heaps, but I will try others if it helps.
I don't really have a spare CD drive laying around, so any other suggestions
before I start buying stuff and ripping bits out of my PC would be good.
Thanks for answering.
This was supposed to be FUN!
"Jim Macklin" wrote:
> Or tell us exactly which "certain cd's" since that implies
> that all other cd's play normally?
> The people think the Constitution protects their rights;
> But government sees it as an obstacle to be overcome.
> some support
> http://www.usdoj.gov/olc/secondamendment2.htm >
> want to answer
> | > this question.
> some answers.
> all power,
> blank
> it on again.
> changed
> previously worked.
> it still does it,
> a bad power
> | supply.
> | Shenan Stanley
> | MS-MVP
> | http://www.catb.org/~esr/faqs/smart-questions.html > |
When you say it "loses power" does the CD stop turning
(sound), does the light go out, or does the computer freeze
or die?
I have seen such failures when a DVD is placed in a CD
drive. It is also possible that those particular CDs are
defective, try them on another computer to see if the
problem follows the CD.
It is also possible that your computer doesn't have the
required hardware to play those games, check the type of
sound and graphics cards you have and compare to the game
specs.
"madmich" <madmich@discussions.microsoft.com> wrote in
message
news:9DA8F0F4-A200-4AA3-A801-C92F4D61A3E5@microsoft.com...
Windows XP PC
Roller Coaster
other suggestions
would be good.
implies
| > some support
| > http://www.usdoj.gov/olc/secondamendment2.htm | >
to
| > want to answer
| > | > this question.
| > some answers.
loses
| > all power,
get a
| > blank
turn
| > it on again.
haven't
| > changed
| > previously worked.
again.. If
| > it still does it,
motherboard) or
| > a bad power
| > | supply.
| > | Shenan Stanley
| > | MS-MVP
| > | http://www.catb.org/~esr/faqs/smart-questions.html | > |
Thanks Jim,
Well, I'll start at the beginning, the pc dies(turns off), light goes out
and everything turns off,then I am unable to turn it back on again (will not
power up) and the only way to start it again is to turn it off at the wall
and then turn it on again.
The drive in question is actually a dvd drive as well as a cd drive, which I
probably should have mentioned.
I am sure these cd's are not defective as they have all worked fine before
this problem.
My pc meets all requirements for these cd's (had to have a higher graphics
card installed for one of them), and as I said before these games have been
working for months perfectly before this problem.
Sorry to complicate matters, but the problem got worse this morning.
I could not turn on the pc at all, the light would go on, then straight off.
I checked all the cords, turned it off at the wall and on again and kept
trying, finally it turned on, but I got no beep and nothing on screen, so I
checked the four little lights at the back that are supposed to go
green(diagnostic LED's), well the top left and two bottom ones were red, and
it just stayed like that. I checked the mainboard book and it says it will
hang like this if "the memory module is damaged or not installed properly".
I'm not really sure what this means.
It finally started up, I don't know why, but I'm glad it did.
How can I stop this happening, it seems like the problems could be related
as they both seem to have something do with power.
Please help, I am afraid to turn off my pc now.
> or die?
> specs.
> Good luck.
> some support
> message
> Windows XP PC
> Roller Coaster
> other suggestions
> would be good.
> implies
> | > some support
> | > http://www.usdoj.gov/olc/secondamendment2.htm > | >
> to
> | > want to answer
> | > | > this question.
> | > some answers.
> loses
> | > all power,
> get a
> | > blank
> turn
> | > it on again.
> haven't
> | > changed
> | > previously worked.
> again.. If
> | > it still does it,
> motherboard) or
> | > a bad power
> | > | supply.
> | > | Shenan Stanley
> | > | MS-MVP
> | > | http://www.catb.org/~esr/faqs/smart-questions.html > | > |
Seems like you are using a Dell machine. From your discription it sound like
a power supply problem.
"madmich" <madmich@discussions.microsoft.com> wrote in message
news:E409EE51-CBEE-4A6A-9398-EEC42BC54296@microsoft.com...
> Thanks Jim,
> not
> I
> this problem.
> been
> off.
> I
> and
> properly".
>> or die?
>> specs.
>> Good luck.
>> some support
>> http://www.usdoj.gov/olc/secondamendment2.htm >>
>> message
>> Windows XP PC
>> Roller Coaster
>> other suggestions
>> would be good.
>> implies
>> | > some support
>> | > http://www.usdoj.gov/olc/secondamendment2.htm >> | >
>> to
>> | > want to answer
>> | > | > this question.
>> | > some answers.
>> loses
>> | > all power,
>> get a
>> | > blank
>> turn
>> | > it on again.
>> haven't
>> | > changed
>> | > previously worked.
>> again.. If
>> | > it still does it,
>> motherboard) or
>> | > a bad power
>> | > | supply.
>> | > | Shenan Stanley
>> | > | MS-MVP
>> | > | http://www.catb.org/~esr/faqs/smart-questions.html >> | > |
Hi beb,
It's not a Dell machine, I know this sounds dumb , but I'm not sure what it
is, I can tell you this it's a MSI P4 mainboard.
What can I do about this power supply problem?
Thanks
> > Thanks Jim,
> > not
> > I
> > this problem.
> > been
> > off.
> > I
> > and
> > properly".
> >> or die?
> >> specs.
> >> Good luck.
> >> some support
> >> http://www.usdoj.gov/olc/secondamendment2.htm > >>
> >> message
> >> Windows XP PC
> >> Roller Coaster
> >> other suggestions
> >> would be good.
> >> implies
> >> | > some support
> >> | > http://www.usdoj.gov/olc/secondamendment2.htm > >> | >
> >> to
> >> | > want to answer
> >> | > | > this question.
> >> | > some answers.
> >> loses
> >> | > all power,
> >> get a
> >> | > blank
> >> turn
> >> | > it on again.
> >> haven't
> >> | > changed
> >> | > previously worked.
> >> again.. If
> >> | > it still does it,
> >> motherboard) or
> >> | > a bad power
> >> | > | supply.
> >> | > | Shenan Stanley
> >> | > | MS-MVP
> >> | > | http://www.catb.org/~esr/faqs/smart-questions.html > >> | > |
