Tom's Hardware > Forum > CPU & Components > CPUs > Pentium 4 a 3.06 temperature problems
Forum CPU & Components : CPUs - Pentium 4 a 3.06 temperature problems
i have
Pentium 4 a 3.06 c/ hyper threating (500FSB)
assus p4p800 deluxe, som on-board,
radeon 9200 128 Mb DDR
I have 1024 DDR (2 of 512)
3 fan in box and 1 orginal from the processor
i have xp professional without sp1
The programs that normally run are azureus, outlook, silent hill 2, dead to rigths e realplayer norton firewall and symantec antivirus
My problem is that my PC block when i play games
the temperature of the processor reaches 75º and 80º
How i prevent this problem
Sponsored Links
75 to 80 celcius. Right? Be sure your heatsink is square, sitting flat on the cpu, and all fan clips are engaged on the bracket before locking the heatsink down with the clamps.
Reply to o1die
i am not sure if i beleive this .... even without a fan the processor would not hit this temp. it would slow down to compensate...
this is full of BS IMHO
Athlon 2700xp+ (oc: 3200xp+ with 200fsb) , Radeon 9800pro (oc: 410/370) , 512mb pc3200 (3-3-3-2), Asus A7N8X-X
Reply to coylter
He has to mean 80 F. That would be around 28 C. One of Tom's video's showed a P4 without a heatsink and it only got to 29 C/ 84 F and shut down. There is no way a P4 can run at 70 C with a fan and heatsink. Even Athlon's don't run that hot.
My System:
<A HREF="http://www26.brinkster.com/amdgamer1/main.html" target="_new">http://www26.brinkster.com/amdgamer1/main.html</A>
Reply to davemar14
I agree, make sure the HSF is properly seated and arctic silver compound is applied. <b>Remove</b> old thermal tape which was included with the Intel heatsink before applying new thermal compound.
<b><i>1024MB-P4 2.8B-RADEON 9500PRO</b></i>
<A HREF="http://arc.aquamark3.com/arc/arc_view.php?run=544326478" target="_new">29,618 Aquamarks</A>#1 in class!
Reply to Kanavit
thanks for your help
Reply to Diabosss
i have 2 pictures
normal temperature
http://www.olaporto.com/elektropar [...] normal.jpg
hight temperature (when i play a game)
http://www.olaporto.com/elektroparade/temp_alta.jpg
thanks all for helping me
<P ID="edit"><FONT SIZE=-1><EM>Edited by diabosss on 02/23/04 10:36 AM.</EM></FONT></P>
Reply to Diabosss
Ok, you definetly have a problem. Either Asus Probe is screwed up, or you need to reseat you heatsink. Download Motherboard Monitor and check the temps in there. Asus Probe is not the most reliable program. Cross reference the Asus Probe temps with the BIOS and Motherboard Monitor. Also, I think your heatsink is not mounted correctly. There is no way a P4 will hit that temperature if the heatsink is installed correctly and running at stock speed. Usually a P4 will start to clock itself down when it hits 70C.
My System:
Reply to davemar14
There are 613 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
