bigd1350
I have Surround Speakers from a Phillips (MX3660D) Home Theater System. (head unit went bad). I replaced it with a Sony (STR-K665P digital audio control center. Speakers, DVD, and Television are connected. The Sub from the old system has a Line cable with RCA connectors. The New receiver has those spring loaded clips that you plug bare wire into. Can anything be done so I can use the sub? Thanks for any advice.
