Help Selecting a 23" - 24" IPS Monitor
Last response: in Computer Peripherals
March 6, 2011 9:10:11 AM
Hello good people,
I am having a tough time finding a monitor that fits my specs.
1920 pixels wide (1080 or 1200 is fine)
IPS
HDMI (with Audio out)
The Dell U2410 is $600 is Canada but that's too much. It was on sale for $400 once but I missed that. So under $400 is the budget. Hopefully less.
More about : selecting ips monitor
a b C Monitor
March 6, 2011 2:12:55 PM
What are you connecting to it that doesn't have separate audio? If you didn't need the HDMI audio output from the monitor to something else, you could get a monitor that has DVI but not HDMI (such as a Dell U2311H or a ViewSonic VP2365WB) and an HDMI to DVI adapter.
a b C Monitor
March 6, 2011 2:47:51 PM
Unfortunately, that combination is very difficult to find in your price range. Even if you buy the adapter I linked below, adding a non-HDMI monitor that meets your other requirements would probably drive the total price over your budget.
http://www.insight.ca/apps/productpresentation/index.ph...
