Tom's Hardware > Forum > General Networking > General Gateways, Routers and Firewalls > Compatability problem with XP and Broadband
Forum General Networking : General Gateways, Routers and Firewalls - Compatability problem with XP and Broadband
Archived from groups: microsoft.public.broadbandnet.hardware (More info?)
I keep getting a message that there is a compability
Microsoft Broadband Networking has a known compatibility
issue with this version of Windows. For an update that is
compatible with this version of Windows, contact
Microsoft Broadband Networking.
Help me to updat this version of Windows
Sponsored Links
Get the update from....
http://www.microsoft.com/hardware/ [...] dMain.mspx
Jason Tsang - Microsoft MVP
Find out about the MS MVP Program -
http://mvp.support.microsoft.com/default.aspx
"nba" <anonymous@discussions.microsoft.com> wrote in message
news:487e01c49078$e8f28660$a301280a@phx.gbl...
Reply to Anonymous
I have downloaded the update but get an error in the application portion.
The router is up to date but the application errors out and no luck
I have SP2 installed
Rick Hebert
"If at first you don't succeed, skydiving is not for you."
Reply to Anonymous
If you have SP2, you can probably not bother with the BNU software.
There's nothing you can't setup with the Base Station Management Tool
anyways.
"Rick Hebert" <rhebert@nightowl.net> wrote in message
news:%23ZiqmMIkEHA.1764@TK2MSFTNGP10.phx.gbl...
> Rick Hebert
Reply to Anonymous
Jason, I to am getting this error message-->
I am running XP SP2 as well, and I dont understand what
you meant by "There's nothing you can't setup with the
Base Station Management Tool"???
Does This mean I can still install the BSManagement Tool
without causing problems?
>-----Original Message-----
BNU software.
Management Tool
>anyways.
out and no luck
>> Rick Hebert
you."
Reply to Anonymous
The update for the MS BNU software is available at
The Base Station Management tool is built into the router. It does not need
to be updated for SP2 as it is OS dependent. Depending on what router you
have, the above update may or may not update your firmware where the BSMT is
stored.
You do not need the MS BNU to setup any router. You can do ALL the setup
via the Base Station Management Tool.
news:03e901c49227$348f4180$a401280a@phx.gbl...
> BNU software.
> Management Tool
>>anyways.
> out and no luck
>>> Rick Hebert
> you."
Reply to Anonymous
There are 739 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
