BIOS Can't See CD-ROM Drive - Hardware Problem?
Last response: in Windows XP
Archived from groups: microsoft.public.windowsxp.general (More info?)
My desktop PC runs fully updated XP Home SP2.
Recently the CD-ROM drive has started disappearing
and reappearing for no apparent reason and now it
seems to have vanished for good. When visible the
drive operates normally but in invisible mode it
not only disappears from My Computer and Device
Manager but BIOS Set-up reports the IDE Secondary
Master as "None". If I then select Detect Hard
Drive the drive name is usually reported as a
string of garbage characters, though on one
occasion the drive was correctly identified.
Unfortunately the latter spasm of visibility
failed to survive the subsequent boot.
I assume from all this that I probably have a
hardware problem and that my next step should be
to replace the drive. However I'd be grateful if
anyone has any useful comments or alternative
interpretations, or can suggest other diagnostic
or remedial procedures which I could try?
Thanks in advance.
| Thanks in advance.
Sure sounds like a bad CDOM. If you verify that the power and IDE cables are snug and
connected to the drive properly and this still happens, replace the drive.
Dave
http://www.claymania.com/removal-trojan-adware.html
http://www.ik-cs.com/got-a-virus.htm
Have you added any new devices to the controller lately?
Have you recently opened up the case and maybe wiggled some connectors
loose?
> loose?
Thanks for the response. Unfortunately the answer to both
questions is "no", though XP detected the CD-ROM drive
as new prior to each of its reappearances.
Related ressources
David H. Lipman wrote:
> From: "Dick K" <rfk2REMOVE@THISbtinternet.com>
> | Thanks in advance.
Thanks for the confirmation. The optical drive is overdue
for an upgrade anyway so I've decided to buy a new one.
It will serve either as a replacement or as an extra drive
if a loose connection is the problem. I'm always wary of
opening the case - this way I hope I'll only have do so
once.
Replace the ide cable with an 80 wire version while you got the hood open.
"Dick K" <rfk2REMOVE@THISbtinternet.com> wrote in message
news:ulhGUhOuFHA.664@tk2msftngp13.phx.gbl...
> > | Thanks in advance.
cables are snug and
drive.
> once.
Thanks for the suggestion which, from what I've found with
Google, is an excellent one. I've ordered a cable.
> Thanks in advance.
Thanks again for all the responses. The problem
seems to have been a loose connection or a faulty
cable. Anyway it has not recurred since I replaced
the IDE cable and reseated all the connectors
Ask the community
