I've been recently searching for a new laptop to replace my old gateway laptop. I've been searching for something below $1000 and that had an i5 or an i7. I will be using it for gaming mostly (when not around my desktop, so not using it for gaming all day).
I usually purchase everything from Newegg, as they have extremely good deals and good service.
So as I searched for it, it pretty much came down to these 5 laptops (been liking the Lenovo the best out of these 5):
http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=2034940032%204022%20103980226%201292318470%201041010743&bop=And&ShowDeactivatedMark=False&CompareItemList=32|34-146-613^34-146-613-TS,34-127-092^34-127-092-TS,34-114-803^34-114-803-TS,34-152-190^34-152-190-TS,34-115-732^34-115-732-TS
I need some advice and help choosing which one will be the best.
Some info and questions on the laptops:
Info:
- I've never used an Acer or a Lenovo laptop, so I dont know their laptop quality/performance.
- I've seen a Sony Vaio about 3 years ago and it seemed really cheap (the material). The one in my link seems different (different model, etc), but I still want some feedback on Vaio's quality/performance.
Questions:
- Any difference between 16" inch with a 1366x768 res than a 15.6" with a 1366x768 res?
- Is the 1366x768 res good for gaming? Does it distort the image and not scale fully?
- How much difference will I experience from the i5 to the i7?
Info:
Questions:
