5108US - Need setup disks/bios how to/cpu upgrades for
toddb
6
Archived from groups: alt.sys.pc-clone.compaq (More info?)
A few questions
any one know how to get into the bios setup for this pc?
where can I down load any setup disks/drivers etc?
anyone replaced the 1.2g processor with a faster one?
This came with pc 100 memory, 100 mhz fsb, any one able to run it faster
say 133 mhz fsb using pc133 memory?
thanks
Toddb (at) toddbailey (dot) Net
yes thats my email address and web site,
with a little editing needed :)
toddb
6
Update
f10 is the bios setup key,
I also found the jumper to go from 100 to 133 mhz, unfortunantly, the
system doesn't even run post on the 133 setting, regardless of memory
type. Oh well, not exactly a over-clockers dream system here.
hh
645
The FAQ answers most of your questions.
HH
"toddb" <toddb@toddbailey(dot)net> wrote in message
news:11645be5148f3ec91173baca6e982bea@localhost.talkaboutcomputing.com...
> A few questions
> thanks
G
Guest
Guest
From what I gather the 5108US is a Slot 1, 200mhz FSB, VIA chipset. It is
made by F.I.C.. Its Non-OEM counterpart is the FIC-AZ31.
You shouldn't have any problems overclocking this board if you use the
proper RAM. Sorry, but PC100 or 133 ram won't cut it on this board..
Hope this Helps.
Best to All.....
TheGarbageGuy
