Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Home network problems with xp home and xp pro
Archived from groups: microsoft.public.windowsxp.general (More info?)
I am trying to set up a home network to connect my laptop (with xp pro) to my
desktop (with xp home) i am using a 3com office conect router as a hub.
With the fire walls on each machine switched off I can see each of the
machines from each other.
I can share files on the laptop with the desktop, but when I try to access
the desktop from the laptop I get the following message :-
\\xxxxxxx is not accessible. You might not have permission to use this
network resource.
Login Failure : the user has not been granted the requested logon type at
this computer.
File and printer sharing etc are switched on etc.
Netbios over TCP/IP is enabled
Bothe machines are set to obrain ip adress automatically
the router has dhcp server enabled.
can anyone help?
Sponsored Links
"Richard" <Richard@discussions.microsoft.com> wrote in message
news:3DB211C8-6630-4F9B-94B3-FEE632BAE446@microsoft.com
> type at this computer.
There is your clue. Security information in a peer-to-peer network is held
on each machine locally, therefore you need to tell each machine which users
are authorised to access it. Set up a User on the desktop exactly the same
as the user on the laptop and see if that helps.
Reply to Gordon
Hi
Share a folder from the desktop. Right click on the folder shared, go to
Sharing, permissions and add "everyone".
Regards
> network resource.
> this computer.
> can anyone help?
Reply to Anonymous
- 0 +
I will try tis when I get Home
Reply to Richard
- 0 +
I already have shared a shared printer aswell as shared folders, but it
doesn't seem to work
"Grego" wrote:
> Hi
> Regards
> > network resource.
> > this computer.
> > can anyone help?
Reply to Richard
But did you grant access for everyone for the folder you've shared?
> "Grego" wrote:
> > Hi
> > Regards
> > > network resource.
> > > this computer.
> > > can anyone help?
Reply to Anonymous
- 0 +
I have checked the box to share the file on the network and also allow the
network users to change my files
is there any other way?
regards
Richard
> > "Grego" wrote:
> > > Hi
> > > Regards
> > > > network resource.
> > > > this computer.
> > > > can anyone help?
Reply to Richard
Yes.
Right click on the shared folder, Properties\Sharing. There you can see a
button Permissions. See if Everyone is added. If it is, check the rights for
ths group.
> regards
> Richard
> > > "Grego" wrote:
> > > > Hi
> > > > Regards
> > > > > network resource.
> > > > > this computer.
> > > > > can anyone help?
Reply to Anonymous
- 0 +
"Grego" <Grego@discussions.microsoft.com> wrote in message
news:9135E972-532E-418A-9574-0B96E27CA961@microsoft.com
If there is not a user set up that is exactly the same as the user on the
laptop, that user will not be in the "everyone" group on the desktop and so
will still not be granted access.
Reply to Gordon
- 0 +
I cannot see the permissions button (the only options I get are, "Share this
filder on the network" and "Allow network users to change my files"
is permissions something that needs switching on?
"Grego" wrote:
> Yes.
> ths group.
> > regards
> > Richard
> > > > "Grego" wrote:
> > > > > Hi
> > > > > Regards
> > > > > > network resource.
> > > > > > this computer.
> > > > > > can anyone help?
Reply to Richard
- 0 +
news:0A6ECCC3-5A0F-472D-878E-507E04053458@microsoft.com
> "Share this filder on the network" and "Allow network users to change
> my files"
In XP Home you can't access the permissions tab unless you are logged-in as
The Administrator. (In Home Edition, only in Safe Mode)
Reply to Gordon
Check the computer name, computer description and the workgroup name on each
of the computers. I have XP Home on my laptop and XP Pro on my 2 desktops.
I think with XP's default security settings they should all be in the same
workgroup. Another thing, is you need to be logged in as an Administrator
to make any of these changes to the networking, file and printer sharing.
I did get all mine working together, but it took me deleting the shares i
started off with and creating new shares for the laptop with XP Home. I
find that not all the admin tools are available in XP Home that I have in XP
Pro.
McG.
news:0A6ECCC3-5A0F-472D-878E-507E04053458@microsoft.com...
>this
> "Grego" wrote:
>> Yes.
>> for
>> ths group.
>> > the
>> > regards
>> > Richard
>> > > > but it
>> > > > "Grego" wrote:
>> > > > > Hi
>> > > > > shared, go to
>> > > > > Regards
>> > > > > > xp pro) to my
>> > > > > > as a hub.
>> > > > > > of the
>> > > > > > try to access
>> > > > > > use this
>> > > > > > network resource.
>> > > > > > logon type at
>> > > > > > this computer.
>> > > > > > can anyone help?
Reply to Anonymous
- 0 +
Thanks for that,
The domain name is the same on both
do you mean I should try "unsharing" the directories which are currently
shared and then re-share them?
regards
Richard
> Pro.
> McG.
> >this
> > "Grego" wrote:
> >> Yes.
> >> for
> >> ths group.
> >> > the
> >> > regards
> >> > Richard
> >> > > > but it
> >> > > > "Grego" wrote:
> >> > > > > Hi
> >> > > > > shared, go to
> >> > > > > Regards
> >> > > > > > xp pro) to my
> >> > > > > > as a hub.
> >> > > > > > of the
> >> > > > > > try to access
> >> > > > > > use this
> >> > > > > > network resource.
> >> > > > > > logon type at
> >> > > > > > this computer.
> >> > > > > > can anyone help?
Reply to Richard
- 0 +
news:25E949DF-A2DE-4A5D-B356-0F8C77D99E63@microsoft.com
> Thanks for that,
If you have REALLY put in a Domain Name, you need to change it to a
"Workgroup"
Reply to Gordon
- 0 +
sorry I meant work group
> > Thanks for that,
> "Workgroup"
Reply to Richard
In article <3DB211C8-6630-4F9B-94B3-FEE632BAE446@microsoft.com>,
>network resource.
>this computer.
>can anyone help?
The: "Logon failure" message indicates a specific problem on the
desktop computer.
Run XP's Network Setup Wizard on the desktop computer. If the wizard
detects the router's shared Internet connection, tell it to use that
connection. Otherwise, tell it that the computer connects to the
Internet through a residential gateway. Reboot the desktop and try
accessing it again over the network.
If that doesn't fix the problem, this should do the job:
1. Download and install the Windows 2003 Server Resource Kit Tools
from http://go.microsoft.com/fwlink/?LinkId=4544 .
2. Click Start | All Programs | Windows Resource Kit Tools | Command
Shell.
3. Type these lines at the command prompt. The second and third
commands are case-sensitive, so type them exactly as shown. Note the
"+r" in the second one and the "-r" in the third one:
net user guest /active:yes
ntrights +r SeNetworkLogonRight -u Guest
ntrights -r SeDenyNetworkLogonRight -u Guest
Best Wishes,
Steve Winograd, MS-MVP (Windows Networking)
Please post any reply as a follow-up message in the news group
for everyone to see. I'm sorry, but I don't answer questions
addressed directly to me in E-mail or news groups.
Microsoft Most Valuable Professional Program
http://mvp.support.microsoft.com
Reply to Anonymous
In article <uYFPzbQuFHA.2864@TK2MSFTNGP10.phx.gbl>, "Gordon"
>>network resource.
>>this computer.
>>can anyone help?
Creating matching user accounts can be necessary when:
1. The computer being accessed runs XP Professional, and:
2. You've explicitly disabled simple file sharing on XP Professional.
In that situation, XP Pro only grants networked access to user
accounts that it recognizes, i.e. that are defined on the local
computer.
However, isn't the case here. The computer that can't be accessed
runs XP Home Edition. XP Home Edition should grant network access to
all users on all computers, with no need for matching user accounts.
desktop computer.
Shell.
Best Wishes,
Reply to Anonymous
Workgroup and domain are not the same thing. A workgroup is a label, a
domain is an IP. And yes, I did mean to unshare a machines assets
completely, then redo the sharing from the beginning for the one that can't
be seen by the other.
McG.
news:25E949DF-A2DE-4A5D-B356-0F8C77D99E63@microsoft.com...
> Thanks for that,
> regards
> Richard
>> each
>> desktops.
>> same
>> Administrator
>> XP
>> Pro.
>> McG.
>> >this
>> > "Grego" wrote:
>> >> Yes.
>> >> see a
>> >> rights
>> >> for
>> >> ths group.
>> >> > allow
>> >> > the
>> >> > regards
>> >> > Richard
>> >> > > shared?
>> >> > > > but it
>> >> > > > "Grego" wrote:
>> >> > > > > Hi
>> >> > > > > shared, go to
>> >> > > > > Regards
>> >> > > > > > (with
>> >> > > > > > xp pro) to my
>> >> > > > > > router
>> >> > > > > > as a hub.
>> >> > > > > > each
>> >> > > > > > of the
>> >> > > > > > try to access
>> >> > > > > > to
>> >> > > > > > use this
>> >> > > > > > network resource.
>> >> > > > > > logon type at
>> >> > > > > > this computer.
>> >> > > > > > can anyone help?
Reply to Anonymous
There are 1003 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
