Battery not charging
Last response: in Laptops & Notebooks
Anonymous
a b D Laptop
May 19, 2010 7:23:16 PM
Hello,
I have this dell inspiron but it does not charge at all. when connected to power the battery does not reduce or increase. the moment I disconect from power and the charge got finished, the computer does not start even if I connect it back to power unless I charge it somewhere else and replace it again. what can I do?
More about : battery charging
May 20, 2010 1:08:09 PM
Hi tula, there are most likely a problem with your laptop motherboard or your battery or even your charger. Maybe you can test which one is faulty by lending the component from your friends with the same model of laptop as you.
Cheers,
Holl0w :)
