Yes No
Ads
Tom's Hardware > Forum > Windows XP > General Discussion > Boot Problems: "Error Loading Operating System"
Forum Windows XP : General Discussion Boot Problems: "Error Loading Operating System"
Archived from groups: microsoft.public.windowsxp.general (More info?)
During general use of Windows XP, my PC crashed and I therefore had to reboot
it. However, now it comes up with the message "Error loading operating
system" in the boot phase. I have used the Windows XP CD to get to the repair
console, (by pressing 'R' on the first screen, only I don't know what to do
from here.
Any help as to how i can repair my PC is greatly appreciated.
Thanks.
Rory.
Reply to rORy
Check here:-
http://www.michaelstevenstech.com/XPrepairinstall.htm
regards,
ssg MS-MVP
> from here.
> Thanks.
> Rory.
Reply to Anonymous
See itis your hardware problem....... ur hard disk is not getting proper power supply..... so remove the SATA cable and re install it....
Reply to aakash_maheshwari
- 0 +
I don't think the console will be of any great help. I found it only good to fix the MBR and fixBoot.
You need to actually continue loading (as if installing a new operating system) which will take you ultimately to a new option to (1) load a new Windows or (2) do a repair.
The Repair choice also uses the "R" key.
If you are not familiar, how to. There is a detail post here: http://www.tomshardware.com/forum/ [...] winxp-tips
I've done repairs many times. It works 90% of the time.
Reply to demax
There are 1934 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Password
By ksiemb, 22 hours ago:
Cannot help with password retrieval. - Forum Rules.
Best offers
Top experts
