First build ever need advice...
Johanthegnarler
895
It's a secured link ^^
<A HREF="http://arc.aquamark3.com/arc/arc_view.php?run=1820114224" target="_new">http://arc.aquamark3.com/arc/arc_view.php?run=1820114224</A>
46,400 , movin on up. 48k new goal.
husker4life
11
ANTEC Black Solution Series ATX Mid-Tower Case with 350W Power Supply, Model "SLK3700-BQE" -RETAIL
Specifications:
Case Type: Mid-Tower
Color: Black
Material: Steel
Drive Bays: 5.25'' x4,3.5''(External) x2,3.5''(Internal) x4
Expansion Slots: 7
Front Ports: USB2.0 x2
Power Supply: 350W
Cooling System: 120mm x1
Motherboard Compatibility: Standard ATX
Dimensions: 18.3''Hx8.25''Wx18.6''D more info>
N82E16811129140 $74.00
$74.00
CD/DVD Burners (RW Drives)
Lite-On Black 52X32X52 CD-RW Drive, Model LTR-52327S, OEM
Specifications:
Write Speed: 52X CD-R, 32X CD-RW
Read Speed: 52X CD-ROM
Interface: ATAPI / E-IDE
Buffer: 2MB
OS Support: Windows 95/98/NT/ME/XP/2000
Features: Innovated SMART-BURN technology
Remark: OEM pack (see pictures for details) more info>
N82E16827106197 $35.50
$35.50
CD/DVD ROM Drives
Lite-On Black 16X DVD-ROM Drive, Model XJ-HD166, OEM
Specifications:
Read Speed: 48X CD-ROM, 16X DVD-ROM
Interface: E-IDE/ATAPI
Buffer: Not specified
Access Time: 120ms ( typical )
Data Transfer Rate: DVD-ROM 8600~21600 KB/sec, CD-ROM 3000~7200 KB/sec
Features: SMART-X Technology, Easy-Tray Design for Both Horizontally & Vertically Use
Remark: OEM (see pictures for details) more info>
N82E16827131603 $29.00
$29.00
Hard Drives
Maxtor 120GB 7200RPM IDE Hard Drive, Model 6Y120P0, OEM Drive Only
Specifications:
Capacity: 120GB
Average Seek Time: 9.3 ms
Buffer: 8MB
Rotational Speed: 7200 RPM
Interface: IDE ULTRA ATA133
Features: Maxtor Shock Protection and Data Protection Systems
Manufacturer Warranty: 3 years
Remark: OEM Drive Only more info>
N82E16822144148 $96.50
$96.50
Memory (System Memory)
Corsair Value Select Dual Channel Kit 184 Pin 1G(512MBx2) DDR PC-3200 - OEM
Specification
Manufacturer: Corsair
Speed: DDR400(PC3200)
Type: 184 Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 3
Support Voltage: 2.5V
Bandwidth: 3.2GB/s
Organization: two 64M x 64 -Bit
Warranty: Lifetime more info>
N82E16820145480 $168.00
$168.00
Motherboards - AMD
ASUS VIA K8T800 Chipset Motherboard for AMD Socket 754 CPU, Model "K8V SE Deluxe" -RETAIL
Specifications:
Supported CPU: Socket 754 for AMD Athlon 64 Processors
Chipset: VIA K8T800 + VT8237
FSB: Hyper Transport
RAM: 3x DIMM for DDR400/333/266 Max 3GB
IDE: 3x ATA 133(1 from Promise 20378) up to 6 Devices
Slots: 1x AGP 8X, 5x PCI, 1x Wi-Fi
Ports: 2xPS2,1xCOM,1xLPT,8xUSB2.0(rear 4),1xLAN,2x1394(rear 1),SPDIF Out,Audio Ports
Onboard Audio: AD1980 6-Channel audio CODEC
Onboard LAN: Marvell GbE
Onboard SATA/RAID: VT8237, 2xSATA, RAID 0/1; Promise R20378, 2x SATA, RAID 0/1/0+1
Onboard 1394: VIA VT6307, 2x 1394
Form Factor: ATX more info>
N82E16813131490 $144.00
$144.00
Processors
AMD Athlon 64 3000+, 512KB L2 Cache 64-bit Processor - Retail
Specification
Model: AMD Athlon 64 3000+
Operating Frequency: 2GHz
FSB: Integrated into Chip
Cache: L1/64K+64K; L2/512KB
Voltage: 1.5V
Process: 0.13Micron
Socket: Socket 754
Multimedia Instruction: MMX, SSE, SSE2, 3DNOW!, 3DNOW!+
Packaging: Retail Box (Heatsink and Fan included) more info>
N82E16819103424 $224.00
$224.00
Sound Card
Creative Labs Sound Blaster Audigy2 ZS PCI Sound Card, Model "SB0350" -RETAIL
Specifications:
Channels: 7.1
Max Sampling Rate: 192kHz
Signal-Noise Ratio: 108dB(SNR)
Hardware Decode: Dolby Digital EX
Digital Audio: 24-bit
Hardware Polyphony: 64 Voices
PC Interface: PCI
Connectors: Line-out, Line-in, Mic-in, Digital Out(5.1), Firewire(IEEE1394), Analog/Digital CD Audio in, Telephone Answering Device in, GAME/MIDI port via extension header, Internal IEEE1394 header and AD_EXT extension header to Audigy 2 ZS Internal I/O Drive(See Details)
External Box: N/A
Remote Control: N/A
Special Features: DVD Audio, THX certified, EAX more info>
N82E16829102162 $88.25
$88.25
Video Cards
SAPPHIRE ATI RADEON 9800PRO Video Card, 128MB DDR, 256-bit, DVI/TV-Out, 8X AGP -BULK
Specifications:
Chipset/Core Speed: ATI RADEON 9800PRO/380MHz
Memory/Effective Speed: 128MB DDR/680MHz
BUS: AGP 1X/2X/4X/8X
Ports: VGA Out(15 Pin D-Sub)+TV-Out(S-Video Out)+DVI Connector
Support 3D API: DirectX®9, OpenGL®2.0
Cable/Accessories: 4 Cables, VGA via DVI Adapter, PowerDVD, Driver CD
Max Resolution@32bit Color: 2048X1536@85Hz more info>
N82E16814102268 $211.00
$211.00
Extend my Standard Warranty on the above qualified items: $64.22
Subtotal » $ 1,070.25
Shipping and Handling Charge »
Tax Instruction for All Resellers How Newegg.com calculates shipping $
FedEx International Economy - PR ONLY APO/FPO - Military ONLY FedEx Standard Overnight FedEx 2Day FedEx Express Saver Choose which State to ship AA AP AE ALASKA ALABAMA ARKANSAS ARIZONA CALIFORNIA COLORADO CONNECTICUT DISTRICT OF COLUMBIA DELAWARE FLORIDA GEORGIA HAWAII IOWA IDAHO ILLINOIS INDIANA KANSAS KENTUCKY LOUISIANA MASSACHUSETTS MARYLAND MAINE MICHIGAN MINNESOTA MISSOURI MISSISSIPPI MONTANA NORTH CAROLINA NORTH DAKOTA NEBRASKA NEW HAMPSHIRE NEW JERSEY NEW MEXICO NEVADA NEW YORK OHIO OKLAHOMA OREGON PENNSYLVANIA PUERTO RICO RHODE ISLAND SOUTH CAROLINA SOUTH DAKOTA TENNESSEE TEXAS UTAH VIRGINIA VERMONT WASHINGTON WISCONSIN WEST VIRGINIA WYOMING
Grand Total » $ 1,070.25
husker4life
11
Im currently using a p3 1.0 ghz, the games i play run fine now but its showing its age for sure, i can wait until socket 939 comes out so it gives me more upgrade options down the road. When is socket 939 supposed to be released?
Crashman
Polypheme
Former Staff
I wouldn't ruin such a nice system with a VIA chipset board when the nForce3 250 was just released. In case you didn't know, that's their second A64/A64FX chipset series, the most feature-packed ever produced, and from a more reliable company. Boards should hit the market very quickly on this one. You've waited this long, no point in jumping the gun only to wish you hadn't later.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
Spitfire_x86
Splendid
Jun 26, 2002
7,248
Though I don't think VIA K8T800 is a terrible chipset, I agree with you
<A HREF="http://geocities.com/spitfire_x86" target="_new">My Website</A>
<A HREF="http://geocities.com/spitfire_x86/myrig.html" target="_new">My Rig</A> & <A HREF="http://geocities.com/spitfire_x86/benchmark.html" target="_new">3DMark score</A>
SidVicious
1,271
I would strongly suggest you to buy two 60GB or three 40GB instead of a single 120GB HDD.
Having multiple smaller HDDs in a RAID array make a lot of sense, depending on what you plan to do with computer, a RAID-0 Stripping array will boost the file transfer speed and RAID-1 Mirroring will increase the reliability of your file storage system.
Considering that HDDs are the most obvious bottleneck in today's computers, a RAID-0 Array will most likely bring you the most noticeable performance increase, files will be loaded in memory much faster, nearly halving the time required to load a file into the system memory.
I personally use two 40GB in a RAID-0 array for my OS & games and an other 40GB for long term media file storage.
Keep in mind that a RAID-0 array is more likely to fail than a single HDD, it's all about risk management.
Fok Speling Misstake
pauldh
Illustrious
Great case choice.
I agree with Crash, nice system, wait for a NF3-250 mobo though.
ABIT IS7, P4 2.6C, 512MB Corsair TwinX PC3200LL, Radeon 9800 Pro, Santa Cruz, TruePower 430watt
