Hello i just got an xp3000 to replace my barton 2500, im using a thermalright sp97 +92mm acoustifan (modded to full speed @2000rpm)
now my 2500 was running at 200fsb so like a barton 3200, my new 3000 is running at stock speed and stock voltage, but its running hotter than the oc'ed 2500.. is this normal?
i did change the thermalpaste (artic silver 5) so does it need to "settle" first??
im running Folding@home so i usually alwasy have 100% cpu usage..
EDIT:
btw the temp difference is about 5 - 6 degrees celsius.
2500@3200 normally running at 50 - 52C
3000@stock running 56C atm
maybe im just bitching, but i was hoping to OC' my new 3000 and pump it up to 200fsb if it can hehe, i got some pretty nice ram and mobo, so that wont be the problem.
EDIT AGAIN:
damn just noticed that there is a 3000xp with stock 400fsb, i guess i should send this one back then or should i keep it and try to oc' it?<P ID="edit"><FONT SIZE=-1><EM>Edited by cesa on 03/29/04 11:14 AM.</EM></FONT></P>
EDIT:
EDIT AGAIN:
