How to connect wireless headphones to tv
nivek_43
4
When i connect my remote headphones to TV it works perfect but when i switch to my HDD recorder by seecting SOURCE>HDMI i can get no sound
TV is connected to Recorder by HDMI cable
i cannot use the headphone socket because it cancells all sound and no one else can hear TV
can you please help
If sound still comes out of the headphones, then you could use an auxiliary splitter and have sound go both to the headphones and a speaker system. Otherwise I would suggest navigating some menus in your television and find sound settings, and try to find something to allow both audio channels to function simultaneously.
tehsplazor
16
Is it possible that your television has audio out jacks, by which I mean the Red and White plugs that say audio out, vs. the Red, White and Yellow ones that say A/V in. Some HDTV's have them, others don't.
tehsplazor
16
nivek_43
4
Thank you for your help ,I have used a splitter and have solved the problem
