Closed
I have a problem check signal display samsung syncmaster SA300 i also using ati
  • Flat Panel Monitors
  • Syncmaster
  • Samsung
  • Monitors
  • ATI
  • Peripherals
Last response: in Computer Peripherals
April 11, 2011 12:17:00 AM
i buy a new monitor samsung syncmaster SA300 i also using ATI radeon but its said check signal cable but when i connect my old monitor its ok.. whats the problem?
More about : problem check signal display samsung syncmaster sa300 ati
April 11, 2011 1:13:10 AM
It could be an incompatible resolution. Connect your old monitor and change the resolution to 800x600 and then connect your new monitor and see if it works.
Score
a b Ô Samsung
a c 114 C Monitor
April 12, 2011 5:51:15 PM
Also check the refresh rate, if your old monitor was a CRT it may be set to a high refresh rate. Set it to 60 for the new one.
Score
November 19, 2011 1:09:30 AM
press the third button from the right its changes the source from DVi to VGA connection. analog/digital. I had the same problem =)
Score
March 8, 2012 8:54:49 PM
Thanks for the excellent troubleshooting advice. You saved me a lot of time, aggravation and money.
Brian in Vancouver
Score
March 26, 2013 11:28:59 AM
Have a question...where is the three button from right on sync master sa300?
Score
June 26, 2013 11:45:35 AM
Just wanted to say thanks that work
Score
June 26, 2013 11:47:35 AM
Score
