ray
630
Archived from groups: microsoft.public.windowsxp.general (More info?)
I have searched and the only answer I've found is that it's a memory
problem.
Dell Inspiron 5150 XP Pro +SP2 all fixes up to date.
Pointer sticks randomly for a few hundred milliseconds after being at rest.
It's not a major issue just annoying.
Any suggestions for a fix would be appreciated.
TIA
Ray
G
Guest
Guest
Ray,
What kind of mouse and software?
I have this problem sometimes with my optical trackball and there are two
causes:
1 Dust has accumulated around the ball which has to be taken out and cleaned
with a lint free cloth and the sensors cleaned with cotton bud
2 A software conflict has developed between the display driver and the mouse
software. I reinstall the mouse software and if that does not fix it
reinstall my Nvidia graphics software.
I have heard that sometimes an old mouse will develop a faulty cable and the
only solution is a new mouse.
Good Luck
Uncle John
ray
630
"Uncle John" <unclejohn@uselesnospam.com> wrote in message
news:e9ST6seuFHA.3864@TK2MSFTNGP12.phx.gbl...
> Ray,
> causes:
> cleaned with a lint free cloth and the sensors cleaned with cotton bud
> mouse software. I reinstall the mouse software and if that does not fix it
> the only solution is a new mouse.
> Good Luck
> Uncle John
Thanks Uncle John
Dell optical mouse into USB socket with Dell software.
Have tried different USB mouse and the problem is still there.
Ray
G
Guest
Guest
John
Use device manager to check your USB devices and make sure that for the
mouse energy saving on the USB port is disabled.
I do find that PS2 mouse connections with Intellipoint are more reliable
than USB.
Uncle John
"Ray" <epitaxial@dsl.pipex.com> wrote in message
news:43297582$0$12181$cc9e4d1f@news-text.dial.pipex.com...
>> Ray,
>> causes:
>> it reinstall my Nvidia graphics software.
>> Good Luck
>> Uncle John
> Thanks Uncle John
> Ray
Nightowl
251
Ray <epitaxial@dsl.pipex.com> wrote on Thu, 15 Sep 2005:
Hi Ray
Are you using a mousepad? If you are, try using the mouse directly on
your desktop and see if that makes any difference. Sometimes optical
mice?/mouses? :) get confused by mousepads, particularly if they're a
light colour or have a bold pattern.
Nightowl
ray
630
"Nightowl" <owl@[127.0.0.1]> wrote in message
news:A$r0B2QMQhKDFw0d@black.hole...
> Hi Ray
> Nightowl
Thank you Nightowl
ray
